Some shots of the rigging and set-up details.
Rudder up:
Stern detail (Open Stern version), mainsheet (green), elastic cords to keep footstraps up (very useful for fast tacking)
Cockpit:
Daggerboard case, mainsheet block, automatic bailer, footstraps and spi halyard and retrieving line (blue):
Asymmetrical Spinnaker setup:
Note the first photo of the post: spi is launched and retrieved in front of the stay (tiedyellow line) so no matter in the tack you’re sailing you can set the chute up... and recover it.
Spi halyard is also a spi recover line and launching spi pole line, it is continuous from upper part of spi (of course
) going down, parallel to mast through a small hole in the deck, to the block in the mast foot then to the block in the prow (which is connected to another block in the aft part of the spi pole, which in turn is connected to elastic cords to automatically retrieve the pole when the spi is recovered) and around the daggerboard case from starboard to the port side (note the came cleat in the starboard side of the daggerboard to hold the halyard, in the last picture of this post). Finally halyard runs from port side trough Frame B and under deck back to the spi to recover it.
It is working perfectly… on land! will see in the water! hahaha
Some shots of the spi setup:
Prow
To forward view, Frame A under spi pole
Inside aft view, Frame B and mast step clearly seen
Cheers,
