It is possible to build very light boats by using 4 mm aircraft plywood at $ 120.00 a sheet. Other weight gains can be made with framed light ply for the top seats and foam sandwich seats and frames. Lightenings holes should be cut wherever possible.
It is all very costly and labor intensive. Until now, many have asked the questions and sometimes argued about it but not many have tried.
If one has problems believing our weights, he can refer to Tom Hill's book. Tom H. uses the same scantlings: 4 or 6 mm Okume.
He rates his 15' 9" Whisp at 68 lbs against 65 for our Row 13 in light version. The Whisp is almost 3' longer and has fancy woodwork.
He has a wide canoe looking like our Scilly Gig, same overall length and beam and announces 49.5 lbs, ours is 80 to 100 lbs and I know one builder who made one hitting the scale at 65 lbs.
Our weights are reasonable. When we announce a light weight version, we expect the builder to pick the best materials, understand that he needs lightening holes and show good skills in his fiberglass work like 50% glass content.
If a 1st time builder uses cheap materials and does a sloppy fiberglass job, he should not complain about the extra weight.
If you are a 1st time builder and want a light boat, build an heavy one 1st.
I am not joking, it is not easy to make a light and strong hull, it takes some experience and more $.
