FS18 max motor weight?
- tech_support
He may need some ballast forward. I would like to see pictures of the boat trimBayport_Bob wrote:Well there's a guy over on Microskiff.com that's mounting an older 50 hp Mercury on his FS18. That should put an end to this debate if/when he posts his performance and draft numbers.
An older 50hp is likely in the same weight range as a new 25hp four stroke. Weight was the focus of my initial question, which everyone seems to have gotten away from. I never asked about overpowering the boat, I asked about weight on the transom. A 25hp four stroke is within the spec'd hp ratings, but is the weight inline with what it was initially designed for?
Josh
Josh
I answered that: 150 lbs.
You can put an heavier engine on there, the boat will trim down by the stern, that's all.
Tomorrow, from the office, I will post the moment to trim and that should end the discussion.
I hope.
Please tell us what engine you want to put on the transom, weight and HP.
That will help us end this exceedingly long thread.
I hope.
Users browsing this forum: No registered users and 18 guests
