GF14 Clamping Board dimensions
mpmlaw
Post by mpmlaw »
I started work on my GF14 today. I am working on cutting out the frame parts from the 1/2" marine ply.
I am following the nesting drawings as included in the plans. The clamping board dimensions show that they should be 10-1/2" inches at their highest points. However, there is only a maximum of 7-3/4" of plywood left after cutting out all the other parts. I went ahead and traced the top of the transom over this 7-3/4" span and cut it out.
Has anyone else had this same issue? Does it really matter?
I appreciate any help or advise.
jacquesmm
Post by jacquesmm »
There should be enough plywood: I see a 1" margin on each side.
Check against you engine bolts. If it fits, it will be fine.
mpmlaw
Post by mpmlaw »
Thanks.
I'm sure it wasn't the plans, it was probably me. Anyway, I'm sure I can make it work.
mpmlaw
Post by mpmlaw »
Oops!!
I figured out what I did wrong. The seat frame that is shown above the clamping board has a recessed area for the seat cover. Instead of cutting the recess out of the whole sheet of plywood, I cut a straight line left to right along the highest points of the seat frame, thus, I cut out a large part of my clamping board with it.
Oh well, live and learn.
jacquesmm
Post by jacquesmm »
It's not technically wrong but it may cost you another sheet of plywood. Sorry.
mpmlaw
Post by mpmlaw »
I thought about a fix. The clamping board I cut is approx. 3"+/- shorter than it should be because of my goof.
However, since the clamping boards are sandwiched against the transom, why couldn't I cut a 3"+/- strip out of my leftover half-inch ply to make up for what is lacking and epoxy it to the transom at the bottom of the middle clamping board and then epoxy the correct-sized clamping board on top of that one?
Wouldn't that work?
Pat
jacquesmm
Post by jacquesmm »
Yes, that would work.
