So here goes--my build of an FB11. Got some 6mm Okoume locally, the epoxy arrived, and I have been laying out and joining panels. I have had some trouble with slow set epoxy catching cold, but found a solution. I think I will spring for some fast set hardener. A fuller ongoing account is at the URL below in my sig.
Mike
The Fishicist--A Build of an FB11
Hofstadter's Law: It always takes longer than you
It should cure.
How much did you mix?
Very small batches are difficult to measure accurately.
I made 6 ounces the first time around, took some care with the measurement. I have dealt with that problem before in wrapping fishing rods. There it's a matter of small quantity and accurate mix requirement. The joint set up fine once I got the temperature up by putting an enclosure over it with a couple of light bulbs lit inside.
I have ordered a jug of fast set hardener. If I mix it with the slow, does the set time scale between fast and slow with the proportions?
I have made considerable progress since last week. Parts cut out and stitched together. It took a bit of wrassling to get it well shaped up. Getting the bow right was the worst of it. At this point I have a 1/2" difference in my diagonals. Not sure whether I should try for any better.
A detailed account is at http://mmcgr.users.sonic.net/FB11/Stitching.html
Mike
Mike
I have made more progress. Got the panels tack welded together and learned why I don't want duct tape anywhere near this project.
http://mmcgr.users.sonic.net/FB11/Tacking.html
The it was on to do the inside seams. I had a misadventure with epoxy putty going nuclear in a caulking tube. It all came good in the end, but it made for a long day.
http://mmcgr.users.sonic.net/FB11/InsideSeams.html
Mike
Mike
Got the outside done today. Chines rounded, hickeys in the outside of the fillets fixed, some ugliness at the bow sanded out and the chines glassed. Spouse is not enchanted by sound of sander and shop vac running for long periods.
http://mmcgr.users.sonic.net/FB11/OutsideSeams.html
Mike
Mike
