Hello All.
Greg, I had told you that I was planning to do it at the end of the month, but I could not stop myself, this morning I decided to flip the hull.
See the pics at the link below:
http://sb18coral.zip.net/
All the best!!!
SB18Coral - Flipped the hull
Congratulations Marcelo.
I took a look at your pictures on the blog and noticed something. The hull lamination schedule calls for fiberglass to the extent of the upper chine. It appears you glassed to the shear. Is this correct? If so that would account for the higher amount of epoxy resin required to laminate your hull. It will make for a strong boat if you did. No worries. I also note you left out the shear clamps. We did the same because I didn’t read ahead enough to realize there were no notches cut out in the bulkheads for them. These should be noted and updated on the plans I think. I didn’t want to piece it together and will add them in the morning. We also flipped our boat today.
Hello Greg,
Congratulations for you as well.
I had told you that I was planning to do it later in July, after my vacation, but I decided save some time and flipped it today.
Yes, you got it. I post a comment about the extra glass. Now we know where is my resin...
http://forums.bateau2.com/viewtopic.php?t=17108
I left the shear clamps to be applied now.
What kind wood are you using for that?
Looking to see your pictures.
All the best.
Marcelo.
All the best.
Marcelo.
