1984 Evinrude approx. wt.?
frazoo
Post by frazoo »
The title on my old Angler states that it had a 115 hp Evinrude at one time. I've been trying to find an approx. weight for that or a similar sized outboard of that time period so I will know (roughly) what I can and can't build into the transom area of the boat. I am planning on using a 250 lb. 60 hp E-tec once rebuild is complete.
thanks, frazoo
... use a bigger hammer.
Built and Using; V12, Cheap Canoe, Modified Honker 14
Strip Canoe (failed)
V12 and Honker Gone to Boat Heaven= Don't build with cheap ply
TomW
Post by TomW »
Fazoo, the 115 Evinrude/Johnson was part of a series that included everything from 88-120 HP, used by both companies. All were 4 cylinders and used identical powerheads. If you can find the weight of any of them you would have a close match to the 115. Try here, http://www.smalloutboards.com/ , they handle older engines and may be able to help you out.
C17ccx, Mirror Dinghy
Spokaloo
Post by Spokaloo »
You will be FAR lighter with the Etec. My 70hp 3 cyl e-rude was something on the order of 180lbs, which I replaced with a 225lb yam 4 stroke 4 cyl. Your motor should be about the weight of the 3 cyl two strokes, and the 4 bangers crept up on 300 lbs in certain circumstances.
E
Jimmiller
Post by Jimmiller »
1984 e-rude will be 286 to 306
Russ5924
Post by Russ5924 »
Just saw a Evinrude 88HP on a other website and the weight was 306 shipped :D
D-5 Done and FL12 Done. GF14 80% done
