The crystals would be very fine. Like sand. if you take some of the resin, and rub it between your fingers, you would feel a fine grit. 4 gallons bouncing around in the back of a pickup, in the southern heat should do the trick.cape man wrote:Thanks Mike. I checked it for crystals (read that on the site I found), but didn't look for tiny crystals. It's in a 4 gallon metal can, but has a plastic pull-out spout. I'll throw it in the truck tomorow and park in the sun. It is curing just as you describe. Stays soft and a bit tacky. Will be great if I can use it. Did I say I was a cheap SOB?
from one cheap SOB to another.... 4 gals of free epoxy is a great deal!
-Mike
