Joel, I'm interested in how you measure the 7 degrees. Are you measuring one side from horizontal or are you measuring the angle across the keel, which would be double.shine wrote:sorry, its about 7 degree
Many boat companies use the first measure, and by that calculation, your average bass boat is about fifteen degrees. That is, each side rises 15 degrees from the horizontal.
The reason I ask is because I've always thought the OB boats were closer to 6 degrees, and the Phantoms were closer to 3 degrees. One way or the other, something is confusing me. The OB series has nowhere near the deadrise that a typical bass boat has, so if Jacques is calling it 15 degrees, I'm confused.
Tag
