Curacao CS 25
peter-curacao
Post by peter-curacao »
Okay after yesterday I decided to glue only one sheet of ply from 15 mm thickness in, so now I have a transom existing of 3 sheets of 12 mm and one of 15 mm with those upstanding frames (see first pic) glued to the last full frame I thickness 18 mm I think the transom is now strong enough to let two elephants sit on it, hell if they want they can have s.e.x. on it as long they take it easy!Image
In the second pic you see the stations cut down to templates for the ply frames so first I’m gone make those a perfect fit before cutting the plywood, its because of all the glass and epoxy they have to be refitted nothing strange under the horizon Image
dustin1
Post by dustin1 »
Peter, those extra layers in the transom will come in handy when/if Mr. pissed off blue marlin makes violent contact with your baby!
8O
jacquesmm
Post by jacquesmm »
I moved the discussion about monster turtles to "Anything else".
peter-curacao
jacquesmm wrote:I moved the discussion about monster turtles to "Anything else".
Again no worry's no problem :wink:
DrBones
Post by DrBones »
That's going to be one 'show boat' once you get done with her. Congrats! Happy to see that now there is a 'bateau' community in Curacao!
Btw..I have a good friend living over there...moved from Florida to Curacao and always wanted to build a boat. He's a top chef with his wife that does the pastries. If you come across him...tell him 'DrBones' says hello and to start building!
peter-curacao
DrBones wrote:Btw..I have a good friend living over there...moved from Florida to Curacao and always wanted to build a boat. He's a top chef with his wife that does the pastries. If you come across him...tell him 'DrBones' says hello and to start building!
Thanks :lol:
If you tell me his name I will certainly do that.
peter-curacao
Transom taped and glassed again and “motorwellâ€
Murry
Post by Murry »
I like it Peter!
Where will your fish box/boxes be located?
Will there be enough room to have a fish box in the center with a live well on one side or the other. I thought you were running a bracket, if so, you should have the entire length of the transom for storage,baitwell, and fish boxes and such. Right :?: :doh:
Looking great,
Daniel
peter-curacao
Murry wrote:I thought you were running a bracket, if so, you should have the entire length of the transom for storage,baitwell, and fish boxes and such. Right :?: :doh:
Looking great,
Daniel
Correct but I'm gone loose some space for the fish/swim door, there is also space beneath the casting deck
Dog Fish
Post by Dog Fish »
Peter
I had my bait well in the transom of my Hatteras and had the drain in the bottom like yours but none at the top on the side like your set up shows. I used a plastic 2 1/4 through hull and put a removable pvc stand pipe with a cap on the top and drilled about 20 small holes just below the cap and just stuck it in the through hull. I had 3 different length pipes so I could change the water height. At the end of the day when done I just pull out the pipe and it drained out fast and all the scales and crap with it. I do all my bait tanks that way, it makes for fast easy clean out. works for me.
