I really want to take on the project of building my own technical poling skiff, but 18' is too long for me. A 16' boat would 10000x's easier to build/store in my garage. Is it possible to build by plans but to remove a 2' section out?
Tommy
Fs18 reduced to 16' long? Is it possible?
Re: Fs18 reduced to 16' long? Is it possible?
You can scale all the lengths to get to 16' but consider that this will increase draft.
How much do think it would affect draft? Also would it change the beam/width. Instead of trimming what about just removing 2' off the back and moving all inside supports forward to keep the boat widthes as wide as possible
If you don't change the beam, it will be the same . . .
The shorter will have less volume but not much less weight, that's how it will affect the draft.
Maybe 1/2".
Many worry about the least 1/4" of hull draft then put an oversized engine on the boat and it goes down 5" by the stern.
I would not worry much about the draft change.
A 16' FS18 will be a very small boat, like a large canoe. Built light, it will plane with less than 10 HP.
Maybe 1/2".
We were thinking a merc 9.9 but still wanted to have front and rear decks as well as a poling platform. Would the boat be to tipsy at 16' for poling and walking around? Thanks
More than the FS18 but less than a 16' canoe.
If I were make the beam wider like 6" would that help with being less tipsy
If you widen the beam more than 10% you will need to change the total interior structure and will have a totally different boat not an FS. There are always trade-offs in picking a design and as Jacque says for this one the slightly more tippiness caused by shortening it is the result.
C17ccx, Mirror Dinghy
Users browsing this forum: No registered users and 20 guests
