1) plywood would be Hydrotek BS 1088 Meranti with the bottom panels cut from 1/2" instead of 3/8". This also changes the butt blocks to 1/2" per the nesting diagram. This is already an option per the plans.
2) the outside bottom would be glassed with 6 oz fabric up to the waterline, the inside bottom and side panels (in & out) would be glassed with 3.25oz fabric.
3) the outside bottom would be painted green with a white waterline stripe and everything else would be a "bright finish" of epoxy and several coats of clear marine varnish.
4) per the nesting diagram, the seat tops are all 3/8" cut from a single sheet of plywood. I would either change this to 1/2" Meranti or some other wood altogether and maybe increase the seat tops to 3/4". I would like the seat tops to have a lighter finish than the darker (hopefully) Meranti. Maybe oak, birch? Or?
5) the frame tops would be cut square (maybe 1/2" radius) to allow for a 3" wide gunwhale (sp) similar to the FL14 "Lake Dreamer" built awhile back.
Let me know what y'all think
John
