I thought I would share som pictures of my CS 25 that I'm building in the back of my warehouse. Got started about 6 weeks ago.
Ready to make the first cuts
Frames
transom
stringers
I think I overbuilt the jig a little
CS 25 Stuart FL
- Walkers Run
CS 25 Stuart FL
Re: CS 25 Stuart FL
Great start! By the looks of it, this ain't your first rodeo. Clean work. I hope you're not going to sand in there too. That place will be full of fiberglass dust
Will
Will
Re: CS 25 Stuart FL
Glad to see another Flooring guy on the board!
- peter-curacao
Re: CS 25 Stuart FL
Great progressto the site and good luck
- Walkers Run
Re: CS 25 Stuart FL
I found some more pictures
over head the flair does'nt reall show up
transom lamination
Wide cloth on the bottom
wide cloth on the port side. I hope the get the starbord side and transom this weekend
Decided to go with cardbord for the counsol, lighter, cheaper. I did use the premium 3M tape though
transom lamination
- Walkers Run
Re: CS 25 Stuart FL
wegcagle wrote:Great start! By the looks of it, this ain't your first rodeo. Clean work. I hope you're not going to sand in there too. That place will be full of fiberglass dust
Will
I built a plastic room for sanding
Re: CS 25 Stuart FL
So what's it gonna be? Carpet or Congoleum for the sole?
Your counsol looks good to, I'm using the same material this weekend for my seat boxes.
Your build is looking GREAT!
Joe H
Joe H
- peter-curacao
Re: CS 25 Stuart FL
that hull looks very fair, wish I had done a good job like that, keep up the good work
Re: CS 25 Stuart FL
Keep up the great momentum! You are FLYING!
