As for a bigger boat... one day I will build myself an 18ft 'putt-putt' clinker... but at the moment, the kombi just will not tow anything that big.
Anyway..back to the build.
Took a quick look out the workshop for some sunset inspiration.
They have been developing the Walsh Bay area recently, and the apartments on this wharf start at 'just' 1.4m aus$!!
And they pay me to work here!
Ok, now for the bow section.
I had been wondering how to finish the bow area ever since getting the plans 12 months or so ago, and it wasn't till after I started building in Jan this year that I came to this solution.
I bend a bit of 50mm x 6mm ply between the two ribs and play with the length and rise of the curve till I think... yeah, looks right.
Then glue up the ends and add a couple of screws to hold it while it goes off.
Next I add a brace in the centre, making sure that the curve is even across the bow.
Then in go the cleats. It is hard to see here, but there is also 12mm ply cleats on the inside if the hull on each side of the bow.
