Birmingham RB14
Re: Birmingham RB14
William Connected with Southern Gent
Building " Shallow Mine "
http://xf20shallowmine.blogspot.com/201 ... -mine.html
Re: Birmingham RB14
As tempted as I was to take a picture of myself standing on the transom as it dried a la Cracker Larry's advice, I decided not to gamble on it.
Instead, I used a pair of pickle buckets I fished out of the dumpster at work and filled with water. They weighed in at about 40lbs each.
You can just make out the curve of the tumblehome along the bottom there.
--Wolfe
"When in doubt, give it more throttle."
Re: Birmingham RB14
The transom was maybe the first thing I laminated on my first build. It was a great feeling holding it after it cured and was cleaned up. A tangible proof that I was actually building a boat. Showed it to guests that Christmas and told them it was going to become a boat... I'm anticipating seeing more pictures of the first RB build I know of that is being posted here. Enjoy your build!
Re: Birmingham RB14
Fresh off of a rare two-days-in-a-row off and I managed to accomplish a great deal. Lots of table and band saw work got my stringers all cut out and congruent. Spent the rest of last night with the broom and shop vac.
This morning before work I set out the plastic and set the stringer pieces out for epoxy.
Slapped on the epoxy with what will turn out to be my LAST overpriced paintbrush. Managed to piece it all together nice and straight. Folded over the plastic, set down a couple of lengths of 2x4 to even out the weight, and applied more pickle buckets from work. Thanks, work!
The next step will be to cut notches in the stringers and stations, then to the dry fit!
Hopefully when I get home tonight I won't find that the cats have pushed the buckets over.
--Wolfe
Re: Birmingham RB14
This morning, I took down the pickle buckets and checked on the stringers. They look good except for the points, where they didn't quite meet up. Guess I should have put something heavy on those especially.
Should I take the time to re-lam those or is a 1/8" gap not going to matter?
--Wolfe
Re: Birmingham RB14
This morning before work, I set up my garage to notch the transom for the stringers. Ideally, I should have just notched one of the layers before laminating everything together. Bygones.
I have the transom clamped to my sawhorses and the router depth set to go through one layer of ply. When I get home tonight, I'll plot the cut and score around it with my pull saw. Then I'll pretty up the notch with a chisel.
Throughout the week, I'll begin assembling the build platform, then finally get to the dry fit.
--Wolfe
Re: Birmingham RB14
I'm really looking forward to watching this one come together.
Re: Birmingham RB14
I'm a little surprised that there aren't more people building this style of boat. I can understand wanting to build a fishing boat. My next build will be a fishing boat.
I guess for me this boat will be art for art's sake.
--Wolfe
- peter-curacao
Re: Birmingham RB14
It is a beautiful boat, if I could use it here I would definitely build it I think reason you don't see much RB's build threads is because her plans aren't released for to long of a time now, so it's a fairly new design at Bateau.com94Virago wrote:I'm a little surprised that there aren't more people building this style of boat. I can understand wanting to build a fishing boat. My next build will be a fishing boat.
Users browsing this forum: Ahrefs [Bot], Google [Bot] and 10 guests
