Push Pole kits?
Push Pole kits?
Are the push pole kits gonna be available anytime soon?
Mike
Matthew 4:19
Matthew 4:19
- tech_support
Re: Push Pole kits?
Not in the near future, we still have the larger diameter carbon sock in inventory, and it does not make sense to re-order until we sell most of it
Re: Push Pole kits?
Can a push pole be built just using fiberglass sleeves and no carbon fiber?
Would weight become an issue? If possible how many layers would be required?
Randy
Randy
- tech_support
Re: Push Pole kits?
sure, it would just be heavier.
Jacques proposed a good idea, we have plenty of uni-directional carbon fiber tape. The uni tape can be wrapped around the mandrel at an angle, two layers going opposite ways (makes a BIAX), or both layers wrapped length wise (then all the CF is in the warp, 0 degree) - then cover that with a layer of the biax sock to squeeze it all together. It would basically build the same thing as what we do with the sock.
