VG23 clear coated topsides?
I've just puchased the plans for the V12 in order to get to know the S&G technique. I intend to move on from there to the VG23 and have some thoughts on the paint scheme. In line with traditional local fishing boats, I'm thinking of a matt dark grey (or black) hull with clear coated top sides. However, I don't know if the topsides are fibre glassed and if so, with how many layers. If they are, would my idea still be feasable? I don't mind if you can see the fibre glass structure a bit from 2 feet away, but it shouldn't be obvious from several yards away.
CH14 built, something with a sail next
Re: VG23 clear coated topsides?
Everything is fiberglassed and in a boat the size of the VG23, there are too many layers to have wood finish.
You can always apply a fake teak veneer like Plasteak. It lats longer than real teak, less maintenance, is lighter and from 1 meter away nobody can tell the difference.
Ok. Many thanks! I'll look into your suggestion and reconsider other paint schemes.
Here's an example of what JM is talking about. This is a VG20 with a deck treatment.
Justin Pipkorn
Vagabond+ Just Right
http://www.amateurboatbuilding.com/justright/index.htm
gallery.bateau2.com/thumbnails.php?album=1281
Otter/Lissa
gallery.bateau2.com/thumbnails.php?album=1197
Otter/Lissa
