Texas LB22
Re: Texas LB22
Yes... big step! Congrats... vrooom. Getting closer.
Re: Texas LB22
Thanks for the support. The rest of the weekend was family and social stuff, but late this afternoon I went down to Nina, and she and I made some pondering breakthroughs on the electric thing. Winter is in the air, but Nina's got spring on her mind.
Says me too Dougster
Re: Texas LB22
Dougster, I was admiring the crisp and straight line you made with your graphite application. I went back in your thread and saw that you used a laser from HDepot. Would you mind letting me know which model laser you used? I think I could get a straight line on the side of my hull with eyeballing it and using a water level, but as I bring the line towards the keel I could see getting some error with those methods that a laser may eliminate.
Hope to see you in POC in 7/2014, btw.
Thanks, Will
Thanks, Will
Re: Texas LB22
Got any pictures with the laser jig Dougster?
Also curious which laser the Dougster used...
- topwater
Re: Texas LB22
Dont know what model but i used a cheap ryobi self leveling laser on a camera tripod to shoot my water line.
Novi 23 finally launched !
Re: Texas LB22
I'll have to go down later and see, but it was a cheapo Home Depot model, I think Ryobi. The line it throws can be a little fuzzy but it works ok. I'm sure a water level would be fine. I just marked spots every couple of feet or so and then taped it to those spots. Took a couple of tries as I recall. If you can get back a ways to check on the tape you'll be fine, the eye won't lie. Up close it's a challenge.
Usually challenged Dougster
Re: Texas LB22
Hey Dougster,
You have been way to quiet over there. You're probably pondering pulling Nina back in the garage and adding the icebreaker option . If you are still on for the Redbud next Saturday (2-15), Bonnie and I will come over and help roll up the sidewalks.
John
John
- tech_support
Re: Texas LB22
Thanks, Shine. She makes me proud, it's true, but she's been looking at her watch and tappin' her foot lately, wanting to splash. I think I'm a little afraid to finish or something, 'cuz I've let this cold weather slow me down plenty. I got spoiled building her inside the little shop and sure don't like climbing around on her in a cold north wind (and we've had plenty here lately). As usual each step is a learning thing for me and the electrical had me pondering. I've finished all the wiring except the gauges so I'm getting there. The lights, bilge pumps, bait pumps (one for fill, one for recirc) are all working. GPS and Sonar are in but not tested yet. The wiring looks a mess and I will try and neat it up a bit next. That will be a challenge, as you'll see here.
"Under the hood", at the transom:
Console:
Here's a peek inside one of the "storage" areas in the stern. She has two batteries, in the stern on the port and starboard side.
I could do a lot better, now, after Dougstering through it all. For now I'll just go with a little wire loom in a spot or two, a million more zip ties, and hope for forgiveness.
John, I'm playing on the 15th for sure and would love to see you and Bonnie. How are you folks doing? After I finish the electrical all I have is running the fuel line (I may move the fuel filter) and then put on the rubrail.
Trusting in forgiveness Dougster
Console:
Re: Texas LB22
That electrical stuff scares the bejesus out of me! I can't wait to hear how that little ETEC moves her along, maybe the perfect power plant for that hull.I'm worried though, the transition from head scratchin and pondering to quietly and effortlessly plying those blue gulf waters,we hope you can adapt.Theres always therapy.
