OT16 Otter completed
Justin Pipkorn
Re: OT16 Otter completed-seat modifications
Post by Justin Pipkorn »
I just completed modifying the seat layout in my OT16/Lissa.
I sailed, motored and rowed my boat named Lissa. I decided to change the seat layout for several reasons.
ROWING: The original removable aft seat with the seat box used for the single rower position meant that I had to find a place to store either item when the other was used. The movable seat means I can position the seat for either one or two rower conditions. Yet untested is whether the seat will stay in position when I am rowing. The seat can be removed entirely if moved all the way forward.
SAILING: The original plan was to sit in the bottom of the boat when sailing. I'm nearing my 80th birthday and changing position fast enough to balance this narrow boat stability presented a challenge. Besides, the seat or seat box was always in the way. In order to reach the tiller, I had to sit too far aft which caused the boat to be stern heavy. After years of sailing with a tiller, the side seats seemed more natural. I'll see what works out when I sail the boat next time.
MOTORING: Once again, I need to sit father forward to balance the boat. I sold my Vagabond and the 2 HP Honda with it so until I get another OB, this part of the experiment will be on the back burner. The motoring that we did wetted my appetite for some more adventures which are beyond the distance I can row. I am eyeing the Suzuki 2.5 OB. I experimented with a steering line around the boat but I think a tiller extension will be my first try.
POTENTIAL CAMP CRUISER: Actually, I entered a Duckworks contest for a Puget Sound Cruiser using a variation of this boat with side seats and a small outboard. http://www.duckworksmagazine.com/06/contest/7/index.htm Now that I've have a little experience with the real boat, I think this variation may be an improvement. There are so many little cruises possible here in Florida that this boat may work out for that purpose.
Justin Pipkorn
Vagabond+ Just Right
http://www.amateurboatbuilding.com/justright/index.htm
gallery.bateau2.com/thumbnails.php?album=1281
Otter/Lissa
gallery.bateau2.com/thumbnails.php?album=1197
bondo
Post by bondo »
That is really nice Justin. The concept is great and the execution is too. I bet it works perfectly. Hey what happened to that contest? I remember your entry.
John Larkin
New Poster
New Poster
Post by John Larkin »
Hello Justin,
First time poster here. I also am planning to build the Lissa/Otter and was thrilled to find such clear pictures of your pretty boat. I hope I can ask you a few questions. I have purchased the plans for the Lissa and have redrawn them in 3D CAD to adjust the sheer and bow shape a little.
1. I want to use a balanced lug rig and am curious if the gunter as designed at 60sf area is too much, too little or about right for sail area. I'd like to go bigger, like 72 sf unless you think that might be over-canvassed.
2. Did you build the sail and daggerboard as designed? Does she exhibit much weather or lee helm?
3. I am planning 4mm sides and 6 mm bottom, would you still recommend this? I will probably go with 6 oz cloth on the outside and 4 oz on the inside for strength and paint longevity. I also want it to be light enough to pick up and move around.
4. How many sheets of each thickness ply did you need?
many thanks in advance,
John Larkin
Justin Pipkorn
Re: OT16 Otter completed-Larkin Questions
Sorry to delay an answer. I've been busy with other projects.
Let me be clear. Are you using the Otter or Dobler Lissa plans? I had both sets and used parts of each. Since I wanted to use 4MM on the side panels, most of the lines for my boat came from the Lissa plans. I believe the bottom panel for the Lissa was a little wider than the OT. I followed the interior framing of the Otter which was much simpler than the Lissa. I built the boat in a "basket mold".
1. I want to use a balanced lug rig and am curious if the gunter as designed at 60 sf area is too much, too little or about right for sail area. I'd like to go bigger, like 72 sf unless you think that might be over-canvassed.
Because of the errors made by the sailmaker, my actual sail is less than 60 SF. When I was considering the build, I was impressed with the reported performance of the lug rig on the Goat Island Skiff, a boat about the same size. I did some low grade graphics comparing the gunter and the lug rig with the same 60 SFA. It seemed that the sail centers of effort were very close. The mast, as I remembered, was longer than the 10 foot spars for the gunter. Another boat of interest is the lug rigged SCAMP. This boat has been pretty highly developed in kits and hardware. I would track down how the SCAMP rig was rigged and in particular how the reefing rigging was finally worked out. The Lissa is over a foot narrower than the GIS or the SCAMP and the shape is conducive to rowing not sailing...tippy! Going forward in the boat to reef the lug rig is chancy. I decided to add the side seats so I could shift position more easily and balance the boat. I have only sailed the boat once since completing the seat mod. I definitely would build the boat with the seat modification.
In short, I think the lug rig would be a good choice. The sail can be dropped by just lowering the halyard. Given a SCAMP like reefing system, the sail should be manageable. Although one wouldn't choose the LISSA as a performance sailer, the reports of the lug rig on the GIS indicate the lug rig is no slouch.
As to sail area, I think 60 SF is fine. The hull is very easily driven in light air. In even moderate air, the boat is scary fast downwind. Having even a little sail area on the windward side could help.
I followed most of Dobler's plan for spars as soon as I figured them out. The daggerboard is also Dobler's design. Joe claimed the board might kick up in shallows. Jacques was skeptical. I haven't sailed the boat enough to comment on weather or lee helm. Mostly, it has a different feel. The length of the hull/beam seems to have some effect here. The bottom has enough rocker that the boat responds easily to the helm. My daggerboard board is rather small but carefully shaped so the boat has to be moving to avoid side slip. The board is about the same as I used in the 7-3 version of the Lissa. In that boat, the board could have used more area...about 12 in chord x 24 inch draft when compared with the race-able Sabots [an 8 foot pram like the D5].
If I were starting from scratch, I probably would have built an off-center centerboard along side the side seats. Dobler has a plan for a pin-less centerboard that might have been ideal... and simple.
I followed Jacques' fiberglass schedule, 12 oz biax, one layer inside and one out. He was striving for a very tough boat. My hull weighed about 200 pounds before the seat modification. The 6 oz/4oz was what I used in the Pepita, the 7'3" version of the Lissa. That little boat was very stiff. Particularly with the seat modification, I think the Lissa would be just fine with that layup and you would save considerable time and materials in fill and finish.
I used 2 sheets 4 mm, 2 sheets of 6mm plus a part sheet of 9 mm and some scraps of 6 mm. For the side seats, I used the better part of a 6mm and part of the 9 mm sheet. The nesting of the Dobler Lissa got four side panels out of two 4 mm sheets. I wonder how long Joe spent fitting that on the drawing. He was working with graphical methods... before CAD.
Let me know if you have further questions. I think your suggested ideas are on the right track.
Justin Pipkorn
Otter/Lissa
John Larkin
New Poster
New Poster
Justin,
Thanks for the great information! I have read and reread your comments several times and they are super helpful. Thanks so much for taking the time to do that.
John Larkin
Justin Pipkorn
John,
Keep us posted on your build.
Let me know what sail rig you choose.
Justin Pipkorn
Otter/Lissa
Users browsing this forum: No registered users and 18 guests
