Hardtop for T-top - adapting canvas top to fit hardtop
tech_support
Post by tech_support »
A local customer built this with our materials and advise.
I happen to see him today and he invited me over to see his work - very impressive 8)
It is H45 divinycell, with a shaped edge (doubled up thickness), then he built the speaker/electric box separate and glassed it underneath. paint is sterling. He chopped the top off and had a plate welded to the stubs, there is a matching backing plate on the topside - so the top is secured well and over a large area (no compression problems).
He said the top weight about 35 lbs :)
antoniekruger
Re: Hardtop for T-top - adapting canvas top to fit hardtop
Post by antoniekruger »
Hi Joel, that looks great - is that frame powder coated aluminium or composite frame?
CC14 splashed
CS23 almost there
tech_support
its the original aluminum t-top frame. He cut the aluminum canvas framing off the uprights, then welded on the flat base, then had it powder coated.
antoniekruger
That is sweet right there - very cool :D 8)
CC14 splashed
CS23 almost there
Walkers Run
Post by Walkers Run »
Joel,
With those plates top and bottom is there any need for high density core inserts at the mounting points?
"Do. Or do not. There is no try" - Yoda
https://youtu.be/nzWO9FVJODo
tech_support
If the plates are large enough, no. I would still drill out the hole bigger and fill/re-drill
Rickk
Post by Rickk »
Sweet!!
