I started the mold for my hatch gutters. Built it to the largest size and will just cut the large ones down to make the smaller ones. Used MDF to build it. If you look close you will see a routed grove that will accept a 1/2" diameter dowl. That will form a grove that accepts a 1/2" gasket. I will seal coat the MDF, fillet the corners and prime it. I need to get about 6-8 parts off it.
Also stood the console up on a piece of malamine. I will use that as a mold to build the rear bulkead of the console onto which the steering and control pod will mount. Basically I will glass it right to the console during the miolding process.
