Rise transom for 25mm at GF16 -how to do?
bernd1
Re: Rise transom for 25mm at GF16 -how to do?
Post by bernd1 »
Hi @ all,
Hello Jaques,
the glassing job is done. Both sides 10cm down 2 layer of 450gr +/-45° biax and 2 layer of 100gr fabric in one shot - maybe overkill :roll: - but I like to have a safety feeling.
To glass in one shot was very easy with a fast hardener. First I satured the sanded area, waited until the thing was sticky and layed after the first layer biax. Wet it out and then repeated the same.
I took alltogether about 4,5 hours and 8 cups to mix the epoxy because of the fast hardener -I used about 30gr Epoxy a time .
BTW, my transom was built from the begining with an additional clamping board - it means the transom is 5cm thick....now a few mm more :wink: .
Replies are welcome :D .
Well, the next step ist to shape the edges and to give a light sanding to fair the whole thing - sanding is a job I don't like :cry:
Bye
Bernd
Noles309
Post by Noles309 »
Looks good Bernd. I went with one layer of biax on mine. All the engine mounting points are well below the riser on mine like Jacques said.
Gary
GF-16 Completed
Build Thread
viewtopic.php?t=58331
jacquesmm
Post by jacquesmm »
It looks good.
For all new builders who wonder about transom heights and different shaft lengths, please see this:
http://bateau2.com/howto/shaftlength.php
It explains how to adjust a transom to a different height than what it was designed for.
TRC886
Post by TRC886 »
jacquesmm wrote:As designed, the transom edge is exactly at 20" above the bottom.
You are not the first one that adds a small filler there. there must be something that leads to an error.
It must be the way we draw that curve.
I am going to add a dimension in the middle.
It's not you, Jacques, it's the motors. In March, 2011, I measured a new 20 HP Yamaha with a shaft length of 23 inches :?
jacquesmm
Post by jacquesmm »
TRC886 wrote: It's not you, Jacques, it's the motors. In March, 2011, I measured a new 20 HP Yamaha with a shaft length of 23 inches :?
I knew that about small engines: I ahd a Nissan at 16", a Honda at 16.5 and now I have a Yamaha 4HP at 17" but I expect all largr engines (20+) to stick to the industry standard.
The problem of non-standard shaft length happens up to 25HP, the kind of engine frequently used on the GF16.
I will add page to the notes. If the builder does not own an engine at the time of the building, he should cut the transom for a 25" and adjust later. It is easier to cut than to build up.
Users browsing this forum: No registered users and 22 guests
