I ran my boat into the garage with the vhf antenna up. It shattered the fiberglass at the piont it enters the steel collar at its base. I was upset.
Once I collected my self I decided epoxy and glass might fix it. I took a small strip of biax and wetted it with epoxy. Then I wrapped it in a spiral fashion around the broken area. Finally I wrapped the repaired area with electrial tape. Epoxy spurted out everywhere. I cleaned it up and went home.
The next day off came the tape. It did not bond to the epoxy. The repaired area was faired with a file and wraped with white electrical tape. It looks almost factory and is srong as can be. While filing I noticed a super high percentage of the repaired area was biax tape. Very itchy work. There was very little epoxy left that didn't absorb into the biax.
I think that is why people are crazy about vacuum bagging. Lots of glass and strength and very little resin and wieght. Please correct me if I am wrong.
I hope my idea might save someone from buying a new antenna or am I the only one who forgets to put his antenna down.
Billy
vacuum bagging with electrial tape
- Evan_Gatehouse
Correct: we used a similar technique to squeeze resin out of our carbon fiber mast lamination, with shrink wrap.
The shrink wrap did not peel off very easily, we may try again with peel ply under the shrink wrap. The peel ply should absorb some of the excess resin.
- New Poster
I never tried paper towels but why not?
What's a stipple roller?
- New Poster
A stipple roller or epoxy layup roller is a soft, spongy, bumpy roller that helps in working out air bubbles but won't lift the cloth. We get them from an aircraft supply house called Aircraft Spruce and Specialty co. Their web site is aircraftspruce.com. They have all kinds of stuff for fiberglass work. A couple of other things that might work for boat building are the flocked cotton fiber and the milled glass fibers they are used for structural filler like fillets and stuff.
Thanks. Aircraft Spruce is a good supplier but quite expensive.
I never tried those rollers but will check them out. Right now, I pour or brush the resin and spread with a squeegee.
We sell the milled fibers and other fillers at BoatBuilderCentral.
- New Poster
