I am correct about the block but maybe wrong about the max. HP. I think they went up to 90 . . . not certain.
Look for Rotax engines. They should fit.
Or cannibalize one from a jetski as we did.
You have to find a bell housing and transmission.
Flyer
Re: Flyer
- peter-curacao
Re: Flyer
LOL is that even possible? first ride would probably be the last one alsojacquesmm wrote:
But you are going to put that 500HP turbo charged V8 in there, correct?
- peter-curacao
Re: Flyer
Found some pics of her, beautiful boat imo, when you look in the engine compartment it looks like the side panels does have a camber or is that an optical illusion? Also looks like a V8 is possible
Re: Flyer
Yes, the engine hatch has camber.That's easy: build the deck in one piece with camber and cut out. I thing there are pictures of how we did it with the jetAbout.
Nice pictures.I wonder what engine that is.
They have a standard bell housing and a Borg warner tranny in there, probably a 1:1, again easy to find. I wonder what that intermediate plate is, maybe an adapter for the bell housing or then they have super duper flex plate damper thicker than normal. Nothing that even a small machine shop can handle.
Peter, it's time that you make friends with a guy that owns a machine shop.
Re: Flyer
I wonder what that engine is. Some flat head V8. I see 8 leads coming from the distributor.
It must be tight in there because they moved the fuel pump to the top. That's too hot = vapor locks.
And that thing in the front looks like a magneto, no alternator.
I would look for something lighter.
Re: Flyer
Thank you. It's great to have engine connoisseurs on the forum!
- peter-curacao
Re: Flyer
Thxkeysrat wrote:Flathead Ford series 8BA, made from 1949 -1953. 100 HP.
- peter-curacao
Re: Flyer
Yes but I was talking about the side panelsjacquesmm wrote:Yes, the engine hatch has camber.That's easy: build the deck in one piece with camber and cut out. I thing there are pictures of how we did it with the jetAbout.
Re: Flyer
What a beautiful looking boat. I love the idea of this in stitch/glue. Seems like it would be another great boat to use a jet ski donor motor. Definitely on board with this idea
Will
Will
