Guttered hatches flush mounted
RCC-SKIFFS
Post by RCC-SKIFFS »
Up for sale.
Guttered hatches
Lid measures 20x15
Gutter is 1.5in wide x 2in deep
Actual opening is 16x11.5
Flange is cut to size
Pvc drains can be added
Different color options available
Standard parts will be grey or white
Gasket is included with every hatch installed
Hatch set w/gasket $240
Precession hinges $25 each
Ready for latch of your choice
Lid can be recessed where latch goes if desired
Pictures are of the plug mocked up
Other hatches can be built Upon request to size/spec. This just happened to be the first size I needed for the fs 18 build
seaslug
Re: Guttered hatches flush mounted
Post by seaslug »
Finally, someone designs and builds a proper hatch with gutters large enough to actually drain. Nicely done, and good luck with sales.
RCC-SKIFFS
seaslug wrote:Finally, someone designs and builds a proper hatch with gutters large enough to actually drain. Nicely done, and good luck with sales.
Thank you. From what i've seen they are about $100 cheaper than others of similar size.
Also, their will be atleast one or two more molds built unless, I find that there is a little demand for them. Then I will make more.
seaslug
Post by seaslug »
You said that you were making hatches for an FS18, what stage are you in building your boat? I finished my FS18 a few months ago and it's an amazing boat in every way. Exceeded my expectations. Light as a feather, more stable than I could have imagined with its narrow beam, 3" draft empty, probably 4.5" with 2 guys, and poles easier than a Hells Bay Glades skiff I've been fishing from for 4+ years. The first time I went to launch, I unhooked the winch strap, without wetting the tires and the boat started to slide off on its own. At some point I'll learn how to post pictures of my build, I'm proud of the way it turned out, and since I couldn't find any decent hatches I built my own and they came out great. I'm up in Flagler Beach if you're in the early stages of the build and have any questions feel free to contact me or come up for a visit. My email is cowdellm@aol.com Mike
Post by Jeff »
RCC-Skiffs, I left you a voicemail on the telephone number we have on file for you. When you receive this post, give me a call as I would like to discuss your hatches in a little more detail. Thank you, Jeff 772.770.1225
