Flyer
Discussions about the free plans distributed at bateau.com and BoatPlans-OnLine.com.
peter-curacao
Re: Flyer
Post by peter-curacao »
jacquesmm wrote:It looks like there is camber in the sides, you should follow the plans. I remember that I started to loft it to adapt to our material and probably obtained a slightly different shape.
But I don't understand or can't find the chamber of the side frames, would it look good without chamber in the sides? Reason I ask is, I can get some full sheets of Panamanian mahogany which I think looks great on the sides (will glass those up to the waterline, above waterline epoxy coat covered with clear coat, inside glassed completely with biax?)
jacquesmm wrote:9 mm frames 80 mm wide would be correct if you use the kind of planking I use.
Yes the planking you sugest here
jacquesmm wrote:Bottom 6 mm core, sides 6, plywood framing 10 mm, deck 4 or plank. All that plus glass in and out.
jacquesmm wrote:I have to see the stringers and the rest of the construction to give an opinion. Build her like a monocoque structure and she will be light and strong.
Yes I was planning a monocoque structure, for stringers I was thinking 3 stringers 1 in the keel and the other two in center of keel and chine. Stinger height same as frames 80 mm
Evan_Gatehouse
Re: Flyer
Post by Evan_Gatehouse »
Peter,
Yes we are here in Curaçao now. I sent you an email on the email you have associated with your account here. If you don't get it, email me at ceilydh at yahoo dot com.
Evan
Ps my phone number here is 683 7523
SK17,MM21/MT24
jacquesmm
Re: Flyer
Post by jacquesmm »
Peter, invite Evan and family for dinner and I am certain he will give you some advice about lofting the lines of the Flyer and more. :D
peter-curacao
Re: Flyer
jacquesmm wrote:Peter, invite Evan and family for dinner and I am certain he will give you some advice about lofting the lines of the Flyer and more. :D
He's not here at the moment, could you be so kind and help me out with my earlier questions above at the top of this page ?
Evan_Gatehouse wrote:Peter, Yes we are here in Curaçao now. I sent you an email on the email you have associated with your account here.
Got it!, I will contact you when you are back on the rock 8)
Evan_Gatehouse
Re: Flyer
Hi Peter,
I'm back on Curacao. Let me know if I could come by and give advice on your project.
Evan
SK17,MM21/MT24
jacquesmm
Re: Flyer
Post by jacquesmm »
Peter, did you solve the question about the camber?
I ma very busy right now but will try to find time to look at the plans.
peter-curacao
Re: Flyer
Evan_Gatehouse wrote:Hi Peter,
Evan
Where more or less did you anchor on Spanish water?
peter-curacao
Re: Flyer
jacquesmm wrote:Peter, did you solve the question about the camber?
No I'm also very busy at work at the moment but maybe I continue this weekend setting up frames,I'm hanging to no side chamber because of reason in quote, but before I do it would be nice if you give your opinion about this
peter-curacao Sat Sep 10, 2016 1:40 pm wrote:Would it look good without chamber in the sides? Reason I ask is, I can get some full sheets of Panamanian mahogany which I think looks great on the sides (will glass those up to the waterline, above waterline epoxy coat covered with clear coat, inside glassed completely with biax?)
jacquesmm
Re: Flyer
Post by jacquesmm »
It would look better with camber. You can always draw the camber your self, it is done the same way than on your CS25.
Sorry but I don't have the time to look at the Flyer plans now. I work 7 days a week, full time on a design that has to be ready within a week.
Evan_Gatehouse
Re: Flyer
Peter,
I've shown our location on the chart:
[img]http://gallery.bateau2.com/displayimage.php?pid=61958[/img]
If you come by, look for a catamaran with blue/green stripes on the hull, flying a small Canadian flag at the stern. Boat name is CEILYDH
Cheers,
Evan
SK17,MM21/MT24
