Yes it works as a filler that's about it, and while we're at it lets substitute the epoxy for wallpaper glue
Again Jaysen it's your boat do whatever you please
When I started my CS 25 there was only one marine shop on the island, if they didn't have what I needed I ordered or waited for the right stuff to arrive, even if it was for something simple as gluing a seat, after all that one had to hold 100 + kg also, well in my case that isterrulian wrote: ↑Sun Feb 26, 2017 9:51 am Still going to do my experiment and I'll let you know.
Anyway the point was, remember, that he didn't have the right materials and he was gluing the seats to the cleats, not the frames to the hull. Of course you want to use the right stuff for the right job, but that's easy for me to say, since Tap Plastics is about five minutes away.
The seats definitely contribute to the rigidity of the hull. The working assumption I was going on was that this rigidity is sufficiently achieved by taping the seats to the hull and also to the associated frames; but of course a secure connection between seats, cleats, and hull can do nothing but strengthen that connection. Obviously, I'm just flapping my lips here; Jacques would be the person who could give you a reliable answer.Id think the tape and cleats are doing the real work and the glue between cleat and seat is less critical.
The cleats at the sides and at top of the frames give you a lots of glue surface what brings the structural strength to the hull, this has to be done with good glue, as I said before I don't see epoxy with fairing filler as a (good) glue, but that's me, you probably want to fillet with the same fairing mixture and tape over that? Yes it will probably hold but imho it's just not the way to do it, I would wait for the good stuff.Jaysen wrote: ↑Sun Feb 26, 2017 11:22 am I understand your logic. The only "question" is the physics of the seat to cleat mechanics. Does it require "strongest glue" when taped? The v12 build instruction list doesn't talk about taping the seat to the hull, just glueing it to the seats.
I think it's a Jacques question at this point.
Okay I had too look that up
Go ahead do whatever you want, why do you even ask, I'm done and gone, good luck on your build!Talking Pony
When a person is talking absolute and utter annoying nonsense at you, and you can’t get away.
What did he say to you?
Ah nothing he was talking pony.
