One of my son's friends had some silly putty the other day, so it's still around.
I asked him if he knew how to lift comics out of the funny paper with it. He didn't, nor did he know what a funny paper was......
Eric's C21
Re: Eric's C21
Thank You, Sorry I made you feel that way. I feel old when my kids say "what is silly putty?
Shop was 70 when I left, I'll check it but I don't think it will be ready to sand today. I did throw it thick in that low line, but I know it needed it. We'll see after I sand. That's why I only did this one batch today. I have no idea of how low these lows are. I miss Cracker Larry a bunch, I hope he gets better soon.Fuzz wrote: ↑Sat Mar 04, 2017 12:13 pm Eric I am not sure how warm your shop is but temperature will make a huge difference in the cure time. System3 says 4 hours to machine sand if the temp is 77f. My work area is usually around 60f and I find it works best for me to let things set overnight.
I do love the QuickFair. I have found it to be pretty forgiving. I mix by eye, 2 scoops to one scoop, and have not had a problem yet. Most of us put it on way too thick and end up sanding most of it back off. As Cracker Larry says "we are not icing a cake here" I found that to be good advise from "The Man"
Re: Eric's C21
Eric sounds like you need to put a guide coat down. Use anything from Krylon fast drying spray paint, I like the bright blue on the purple mix, but black works well on Quik fair, keep the can moving so you only get dots. You can also use graphite spread very lightly, or there is a product on line specifically made for guide coats. Once you put it down sand the hull lightly and you will see the highs and lows very clearly and how deep the lows are. This will prevent you from wasting Quik Fair.
Re: Eric's C21
Tom is right. I've wasted a ton of quick fair. I've used over a gallon on my xf 20....so far. If I try to sand too quick when its cooler in my shop it instantly gums up my sand paper even though it feels dry. If it's below 70, i let it sit overnight before sanding it. I really need to get my fairing done quick. Looks like you're about to pass me up.
Re: Eric's C21
Let me get this straight, I put the guide coat on before Quick fair? Then sand?TomW1 wrote: ↑Sat Mar 04, 2017 5:19 pm Eric sounds like you need to put a guide coat down. Use anything from Krylon fast drying spray paint, I like the bright blue on the purple mix, but black works well on Quik fair, keep the can moving so you only get dots. You can also use graphite spread very lightly, or there is a product on line specifically made for guide coats. Once you put it down sand the hull lightly and you will see the highs and lows very clearly and how deep the lows are. This will prevent you from wasting Quik Fair.
- AmbitiousRookie
Re: Eric's C21
I haven't done a boat yet but have done a few tractors and couple semi cabs and assuming it the same process. I would fill just obvious low spots then light spray of black rattle can to where it looks like confetti or if you have the carbon powder stuff and do a light rub over. When you go over it with your board .repeat this tedious process till it comes out as straight as you like. But I would think you would need to put a thin coat down first since fiberglass is not remotely smooth
Re: Eric's C21
Thanks, I think I'm on track. What I filled was clearly low. I plan to do the other side tomorrow. It to has the same obvious lows. Then I'll spot fill the rest of those two surfaces and move on to a guide coat. It's my first boat build so some of this is new to me.AmbitiousRookie wrote: ↑Sun Mar 05, 2017 2:03 pm I haven't done a boat yet but have done a few tractors and couple semi cabs and assuming it the same process. I would fill just obvious low spots then light spray of black rattle can to where it looks like confetti or if you have the carbon powder stuff and do a light rub over. When you go over it with your board .repeat this tedious process till it comes out as straight as you like. But I would think you would need to put a thin coat down first since fiberglass is not remotely smooth
- AmbitiousRookie
Re: Eric's C21
The left side to me looks a little heavy on auto you would be going for almost see though except for the low spots.
Re: Eric's C21
I think you may be right. I'll sand it down tomorrow and try to learn from that first coat. I really appreciate all the help.AmbitiousRookie wrote: ↑Sun Mar 05, 2017 2:13 pm The left side to me looks a little heavy on auto you would be going for almost see though except for the low spots.
