I'm still working on my sk14 and haven't started on the FS14 but am thinking and planning it. I have looked at the low shear version but decided I want to keep my freeboard for seaworthy reasons. I do like the sole on the low shear and am thinking about doing this. My question is this. If I install a sole using the top of the stringers as the location of the sole will it be self bailing?
Still thinking about the jet drive and what to do about the bottom. I looked at the ph18 build and the tunnel (pad?) that was installed reportedly designed by Outboard Jet. I asked in another thread about a tunnel but I think I was more thinking about a pad rather than a true tunnel or pocket drive.
FS14 sole
Re: FS14 sole
I understand I will have to run pvc pipes for water to drain from the front compartment to the middle compartment and from there to the transom for drainage.
Re: FS14 sole
Check out this video of a FS14 with jet drivewannabatc wrote: ↑Thu Apr 20, 2017 10:18 am I'm still working on my sk14 and haven't started on the FS14 but am thinking and planning it. I have looked at the low shear version but decided I want to keep my freeboard for seaworthy reasons. I do like the sole on the low shear and am thinking about doing this. My question is this. If I install a sole using the top of the stringers as the location of the sole will it be self bailing?
https://lm.facebook.com/l.php?u=https%3 ... hrHEvA&s=1
