Not really, not for what I do with a CNC. You would have to see one of these running a 2 1/2" indexable drill at 14" a minute in Stainless to understand. The CNC you are talking about would not be accurate enough either.Jaysen wrote: ↑Mon Jun 12, 2017 4:00 pmThose home made $500 units seem a bit more attractive now?Eric1 wrote: ↑Mon Jun 12, 2017 3:50 pmJust ridiculous what repair costs on CNCs. The transmission will run me 14,555.00 and the spindle rebuild was 8,800.00.Aripeka Angler wrote: ↑Fri Jun 09, 2017 10:16 pm I hear you, I had a cnc saw down on Monday.
Glad to help, looking forward to your primer photos
Eric's C21
Re: Eric's C21
Re: Eric's C21
yeah, you are way to big. But it sure would be nice if you could DIY something that would work...
Re: Eric's C21
Re: Eric's C21
Thank you Carlos! I plan to take my primer to Lowes and ask them to mix my primer up too.csotelo wrote: ↑Fri Jun 09, 2017 10:32 pm Looking good, Eric!
Once you got the primer, open the can and stir it. Mine (Interlux) is so thick, even after I thin it as recommended that covered all marks of 60gr sanding in the first coat. It can save a good time and don´t compromise the results.
Regards,
Carlos.
End of the day report.
XXX 1. Fair last two strakes. Filled Complete! XXX
2. Dam and fill upper side panel to transom. Filled and Sanded, needs another pass.
3. Fillet the strakes.
4. Fair the last side panel.
5. Fair the transom again.
6. Mount castors
7. Wash and prep for primer
Strakes from transom
Tomorrow's plan is to pull fillets on the strakes and start filling the last side panel.
Re: Eric's C21
Eric, That is going to be one slick boat!! Jeff
Re: Eric's C21
Thanks buddy! By the way I got my shipment in today! Thank Y'all, As always very fast delivery!!
- glossieblack
Re: Eric's C21
Does the shipment include primer? I'm sure looking forward to seeing her primed.
Re: Eric's C21
No, I've had the primer a while. It was silica,graphite and some 3/8 Nap rollers and frames.glossieblack wrote: ↑Mon Jun 12, 2017 6:54 pm Does the shipment include primer? I'm sure looking forward to seeing her primed.
I hope to need all of this by the end of the month!!!
The rollers look to be top notch!! I still plan to run them over some duct tape though.
Re: Eric's C21
Hate to hear about the CNC break down and its costs. That would put a serious damper on the boat building budget
On the up side you have a whole bunch of folks eagerly looking forward to primer pictures.
Users browsing this forum: Ahrefs [Bot] and 7 guests
