Thank you Marc! It is nice building inside with the AC on. I'm gonna head back in the morning to finish this round of sanding.
Eric's C21
Re: Eric's C21
Re: Eric's C21
What??? AC??? That would be fantastic, it was 103' in my shop yesterday at 1800.
Your boat is looking great!
Richard
viewtopic.php?f=12&t=62146
- BB Sig
Re: Eric's C21
The boat is looking good but a sailor with a high and tight!? What did you do in the Navy?
Re: Eric's C21
I took after my Mom plenty of hair. My brother took after Dad, Pattern baldness.
Thank You! I feel for you. It gets to 90's in the machine shop with the AC's but we're close this week. No metal being cut means not heat generation from the motors or the cuts!Aripeka Angler wrote: ↑Thu Jul 06, 2017 4:47 am What??? AC??? That would be fantastic, it was 103' in my shop yesterday at 1800.
Thanks Barry! I was an electronics tech. I went to "A"school with a bunch of Marines in Great Lakes. Spent more time with them than I did the other sailors. Our first instructor was a Gunny, I had nothing but respect for that man. He was smart as a whip and squared away. My first Chief was a slob, no respect for his uniform or person. That was pretty much the course of my tour of duty.
I joined the wrong branch of service to be honest. I did like Sea duty but I never fit in like I did with those Grunts.
Besides all that, I love the haircut. Cool in the summer and quick in the shower.
Mugshot.
Re: Eric's C21
I finished sanded the second half of the boat today.
I found a couple of places I needed to fill.
Probably where the air file got out of my hands.
Filled.
Spot in spray rail fillet I didn't like.
Filled.
After two coats of primer this is my average surface. I'm going to add another two coats and hopefully it will fill the "orange peel. I don't know, There was a tremendous difference from coat one to coat two. I'm wanting to avoid trying to throw quick fair that thin. It just seems to sand off when I try that. What do y'all think?
Filled.
Filled.
Re: Eric's C21
Adding more coats won't fill in the orange peel. If anything it will just make it heavier. You should be able to sand the orange peel out, but with only 2 coats on there you risk burning through the primer, adding more coats will give you plenty to work with to then sand it flat again. When rolling or brushing, you're better off putting thin coats on and sanding between each coat. It's a pain in the ass I know, but it's easier to flat off the roller texture from one thin coat. If you do 3 or 4 coats without sanding, the texture will build up and you'll end up sanding 2 of the coats off again to get it flat.
Re: Eric's C21
Ok, That makes sense. I'll just do one coat at a time, sand and repeat. This is gonna take a while, stay tuned..dbcrx wrote: ↑Thu Jul 06, 2017 2:46 pm Adding more coats won't fill in the orange peel. If anything it will just make it heavier. You should be able to sand the orange peel out, but with only 2 coats on there you risk burning through the primer, adding more coats will give you plenty to work with to then sand it flat again. When rolling or brushing, you're better off putting thin coats on and sanding between each coat. It's a pain in the ass I know, but it's easier to flat off the roller texture from one thin coat. If you do 3 or 4 coats without sanding, the texture will build up and you'll end up sanding 2 of the coats off again to get it flat.
Re: Eric's C21
After thinking about the boat last night. I came in this morning and put a guide coat on the primer on a small section.
Light spray of Dykem:
I put away the RO sander. I've about decided it is useless as tits on a fish for this work. I dressed my blocks with 120 and went to work.
As DBCRX posted it's a PITA, but in the end I think it will be worth it. I'm getting a very slick surface doing this but it is gonna take some time.
To get the orange peel out I have just barely went through the primer in a couple of spots. I plan to work the entire boat and prime it again.
Fellas it's been good to know you.
Re: Eric's C21
That looks like it's going to work, but are you sure you want a flawless mirror finish?
