Knew you would end up doing a guide coat. It is looking great. Just think when you get it done with 120 and then have to sand with 330 for the final coats, then you are really done with prepping.
Eric's C21
Re: Eric's C21
Re: Eric's C21
I finished sanding the first side today. I had machine repairmen on the floor all day. Had to rent a larger forklift to get the transmission off the machine. Lifting a $25k gearbox twelve feet in the air at the tip of six foot long forks will tighten your pucker muscle more than you would think. We get to do it again in the morning. Yay
Sorry no pictures today.
Re: Eric's C21
I can't wait to see what you call "finished sanding"
At my old job I picked million dollar plus stuff off of a boat a lot. Never thought much of it, it was an oil companies money not mine. It is a whole different deal when it is your nickel on the line. I hope all goes well for you tomorrow.
Re: Eric's C21
Thank for the well wishes. I does wad me up some, the rental lift has a loose clutch and that don't help.Fuzz wrote: ↑Mon Jul 10, 2017 8:12 pm I can't wait to see what you call "finished sanding"
I'll try to get a decent picture tomorrow after the install. It's doesn't convey well in pictures. I' basically taking the primer down to a 120 grit finish. then I'll prime again and sand that down to a 220 grit. I really don't want to go further than that because I'm concerned about paint adhesion.
Re: Eric's C21
I thought S3 (which I think your using) is no finer than 120. Might be worth checking the application notes.
Re: Eric's C21
Check the EMC surface prep too. I know there was something there that surprised me. Either way that EMC is nice stuff to work with. I have had a peeling issue that is due to improper prep between topcoat layers. I'd also suggest NOT using the reducer. Everything was much better without the reducer.
Good luck.
Good luck.
Re: Eric's C21
Thanks Jaysen for the heads up. I will double check before I sand down to 220.Jaysen wrote: ↑Mon Jul 10, 2017 9:21 pm Check the EMC surface prep too. I know there was something there that surprised me. Either way that EMC is nice stuff to work with. I have had a peeling issue that is due to improper prep between topcoat layers. I'd also suggest NOT using the reducer. Everything was much better without the reducer.
Good luck.
Fuzz, this is the surface after two coats of primer.
A boat builder on a facebook group said he thought I didn't mix the primer enough. I don't know, I thought about buying a cheap blender to mix the primer for a few minutes to see if it helps.
This is after block sanding with 120.
- glossieblack
Re: Eric's C21
Well from here it looks the goods after the 120 block sanding. But I'm not exactly close, and neither is Fuzz!
Seriously though Eric, you're doing a great job.
Re: Eric's C21
Thanks Bro, I hope so. I just don't want it to look bad after all the effort.glossieblack wrote: ↑Tue Jul 11, 2017 8:12 am Well from here it looks the goods after the 120 block sanding. But I'm not exactly close, and neither is Fuzz!
