Transom
R-Kid
New Poster
New Poster
Transom
Post by R-Kid »
I am looking for some help with my transom ( 27 Blackfin) . Currently it is a notched transom. I want a full transom so I can put a bracket on it. My transom has a curve in it. Will coosa flex enough? I will attach some pics thx
R-Kid
New Poster
New Poster
Re: Transom
Post by R-Kid »
My vision
narfi
Re: Transom
Post by narfi »
Thin pieces flex easily.
You can laminate multiple thin sheets into a composite curved thicker piece that wants to be that shape.
bateau-webmaster
Re: Transom
Post by bateau-webmaster »
I would go with 1/4 inch if you go the Coosa route. As Narfi said thin sheets flex more easily. You could also use our AquaPlas III Transom Board, which is more flexible than Coosa, but still very durable.
R-Kid
New Poster
New Poster
Re: Transom
Post by R-Kid »
Thanks for the replies. What material would you use? Aquaplas ? How thick should I buy. I need a total thickness of 2 3/4 inches.
jacquesmm
Re: Transom
Post by jacquesmm »
There is more to it than just the thickness: frames and stringers play an important role.
For the transom, build up with several thin layers of whatever material you prefer, epoxy glued.
I would use GelMagic epoxy glue and layers of Aquaplas or marine plywood. The 1/2 Aquaplas will bend, for plywood, use layers of 1/4", max. 3/8.
If you use foam, you MUST use foam with high compression strength.
