Thank You Topwater.
No issue with the high build, it's doing what it is suppose to do. I'm getting a real nice finish.
The thing is to get there I have cut through in many places. To cover these without having to have as heavy a build
I'm going to surface primer. I have discussed this with Jamie and Robin at EMC.
Jamie thinks I would be fine going on to topcoat. I suspect he's is most likely correct.
That said, I don't want to risk the paint coming off the boat a year from now. Though I think that is less than a 1% chance of happening.
Robin at EMC has advised me that if this were her boat she would go to surface primer as well.
I simply weighed the pros and cons.
Pro's:
1. I'll get a more even color from top coat.
2. I reduce the chance of paint adhesion issues. Same primer from topcoat manufacturer.
3. Reduce the chance of losing my finish from a heavy build of primer.
Con's:
1. Additional cost. (some what negated as this will last over several builds)
