Eric's C21
Eric1
Re: Eric's C21
Post by Eric1 »
Thank You Richard. I'm trying to do it right. :)
I got myself moving finally. I premeasured 6, 6oz batches of epoxy with 2 oz. of graphite for each one. I have 4 ounce of resin in the Solo cups and the hardener is in the squeeze bottle. I get good control of the mix doing this. That is a little more than I used on the last coat but I know I'm going to change the rollers three times. The 9" nap roller soaks up about 2 ounces just to wet it out. I also used a 4" foam roller to "Tip" and a heat gun to break bubbles after rolling.
After first two batches are rolled.
HOORAH!!! Bottom Coat is Finished and tape has been pulled! :D :D :D
I'm pretty happy with the results. I enjoyed the testing I did and I learned a little along the way.
To me that is part of the reason I'm building the boat. I've learned a good bit about the process so far and I've learned about myself.
In everything you do, take advice from the experts, but also try things you think would improve on the "norm" and debunk what you think may be un-needed. This is the true process of gaining wisdom. Thanks to everyone for their input and advice! :D
Re: Eric's C21
Post by Jeff »
Absolutely great work!!! Jeff
Aripeka Angler
Re: Eric's C21
Post by Aripeka Angler »
Nice work!
Richard
Bare Bones build thread...
viewtopic.php?f=12&t=62146
peter-curacao
Re: Eric's C21
Post by peter-curacao »
Looks great 8) Any reason you didn't continue the waterline over the transom?
Re: Eric's C21
Post by Fuzz »
Ok we need a little pole here.
Will he be able to resist sanding this coat or not :doh:
Eric1
Re: Eric's C21
Post by Eric1 »
peter-curacao wrote: Thu Aug 31, 2017 1:05 pm Looks great 8) Any reason you didn't continue the waterline over the transom?
It's not needed for fro the intended purpose. :)
Eric1
Re: Eric's C21
Post by Eric1 »
Thanks Y'all! :D
Please take Fuzz up on any wager he makes about me sanding this coat! :lol:
Re: Eric's C21
Post by Fuzz »
I will be a believer once the hull is flipped :D Until then...........................
Eric1
Re: Eric's C21
Post by Eric1 »
Fuzz wrote: Thu Aug 31, 2017 2:14 pm I will be a believer once the hull is flipped :D Until then...........................
:lol: :lol: :lol:
