Thanks Browndog, Marc and Mr.Paul!
All this talk of me doing more sanding on the bottom really cracks me up!
Happy Saturday my fellow boat bums! We have glorious weather here today so I'm inside with Danielle solving a minor issue with the rub rails.
After looking at Jacques drawings for the top edge of the side panels I wanted to shift the dimensions to accommodate cutting these from a single panel. After moving eight foot sections in my CAM system I could not get dimensions I could easily measure. Plus I didn't think the batten I used would bend the same over so few points.
My solution is to tape up poster board sections wider than the 2" wide rub rail I intend. I left that hanging below the edge of the boat. Once it was over the entire side I used a razor against the edge of the boat and cut the waste paper even.
Here is Danielle doing her impression of a Price is Right model. She is so much fun to be around.
Now I take a small square and mark a 2" line from transom to bow. If you do this keep your left thumb against your right ring finger to keep the square and pencil moving together. Your hands are very stable this way.
Everything above the line is waste. This should allow me to move this template around on the plywood to minimize waste. I know I can get one layer from a single sheet for both sides. I may use two layer of 1/4" though. I will mock it up before I decide.
Eric's C21
Re: Eric's C21
Well done Eric!!! Nice system!! Jeff
Re: Eric's C21
Very slick there Eric. That should make installing the rub rails very clean.
Re: Eric's C21
Eric nice use of the scribe method. My dad taught me that a long time ago when working with wood. Everything is looking good guy.
- glossieblack
Re: Eric's C21
Re: Eric's C21
I think I'm starting to figure out your thought process. This kind of scares me.
You won't be sorry that you are putting on the wood rubrail sub-rail.
Remember as you cut the wood strips that each will be a different width in order to match the angle of the deck or gunwale.
Looking good!
Build on...
Looking good!
Build on...
Richard
viewtopic.php?f=12&t=62146
Re: Eric's C21
Thanks Fellas. We didn't layout the other side. Danielle wanted lunch. After we enjoyed the day just goofing off.
Re: Eric's C21
Thanks Richard. I'm going to leave them proud so I can plane that surface after the flip. I noticed the angular shift from the creeper I used to block sand any hanging fiberglass.Aripeka Angler wrote: ↑Sat Sep 02, 2017 8:10 pm I think I'm starting to figure out your thought process. This kind of scares me.
Looking good!
Build on...
Re: Eric's C21
Happy Labor Day!
I got kinda bored with no dove field to hunt so Danielle and I came to the shop to layout the other side.
Such concentration!
Y'all have a great day!
Such concentration!
Re: Eric's C21
Must be great to have your kids take an interest in your project. Mine just looked at me like I was nuts
Users browsing this forum: Bing [Bot], Yandex [Bot] and 9 guests
