I was wondering if there were any plans for something similar to a freeman 37. I didn't see anything but i figured id ask anyhow. I really like the cs25 but i really wanted something between 32' and 37'.
http://i502.photobucket.com/albums/e424 ... 4287ef.jpg
Plans similar to F37?
Re: Plans similar to F37?
After using the search I see others have already asked this type of question prior. I saw a post stating that it was on a list to draw up. I hope that is still the case. It would be a very cool build I think.
Yes, I still plan to design a larger CS25, about 28'.
I'm looking to build a boat like the CS25 in the not-so-distant future and was hoping for a 27' or 28' version by that time. I'm hoping to start buying plywood sheets and epoxy for the hull within the next 12 months.
Would you be able to give an approximate time frame for an eventual plan for a 27-28' version of the CS25?
Thanks.
Thanks.
Out of curiousity, what is the big forward section of the Freeman 37 used for? It looks like a massive waste of boat to me, but I can't really tell if it is a huge cabin up there or just a walking area for fishing. I can't imagine needing that space for walking around to fish when it could be done on a deck. And as Cats go, the Freeman 37 looks very narrow for its length. I'd have to think they accommodate that by making a very heavy hull that requires major horsepower. Like 600hp?
A boat that is much nicer than the F37 would be the Woods Skoota powercat. He has them from 28' to 32' in demountable designs. They are rated to 25mph or so light ship, so if you want the speed of the Freeman, you'd have to find a different approach. The Woods cats are more efficient (might get 6mpg, yes 6 mpg at cruise of 10kts, not 6gpm at WOT like the Freeman) and make much better use of space and still have a darn nice cockpit for fishing. Okay, I know my compare isn't fair, but if you have the power, you use it, and if you are about economy, you use it. I am building the demountable 32'.
Otherwise, if you want that big fast cat to get you to fishing grounds in a hurry, I don't know of any powercat designs that are that massive. If you just want a big and fast fishing boat, then the Mertens 28' would be all the boat anyone would need without the wasted forward section. It looks like it'd be a really dry ride. Of course, it'd ride differently than the F37 cat hulls. And if you want fishing space, the 28 could probably be modified for more cockpit.
Caveat: I like fishing a bunch.
