So I purchased the unfinished hull from rtboating here on the forum. I saw the ad locally and jumped on it. Roy dropped off the boat yesterday and it's sitting in her new home for a few months. I just got my guide license this summer and plan on turning this into a guide boat for here in Homosassa. I'll have lot's of questions and any help will be greatly appreciated.
my main questions are going to be about the layout of the boat once i get to that point. I'm familiar with the glassing process as this wont be my first time doing fiberglass but will be the first time using epoxy...
Cpt. Sean Roush
XF 20 Build
Re: XF 20 Build
My first concern is the outside of the hull. It is pretty much finished and coated with steelflex on the bottom(previous owners work). i've noticed lot's of air bubbles on the sides. how much of a concern is this?
I plan on sanding down the bad ones and re glassing over them with a combination of drilling a small hole and trying to inject the smaller ones... Or should i bite the bullet now and sand down the sides completely and restart???
Anyways off to start mixing epoxy and starting to fillet these stringers in...
Re: XF 20 Build
I think you'll love working with epoxy. Good luck with the build!
If it were me and from the large amount of air in the cloth, I would take it down. The real concern to me is if the painted glass on the bottom looked that way before paint. Hopefully others will chime in.
Re: XF 20 Build
that port side there is the really bad part the transom and and starboard side arnt to bad... I'm guess the 1708 didn't get enough resin in it...
- peter-curacao
Re: XF 20 Build
It does look like that under the paint, look at the waterline spots don't end in a straight line like in the picture
You're sure it's air/dry spots not just sanded spots? it's hard to tell from the picture
Re: XF 20 Build
My camera tends to embellish things a bit alot of it is sanding but alot of air too...previous owner states " The bottom was fine the only delams I had was those couple of spots on side and on that top line"
I'm going to take his word for it for now and only sand out the really bad spots. if i do redo it it will be after i finish the inside of the boat.
Re: XF 20 Build
Just took a closer look at your pictures. I don't believe the previous builder used marine plywood. You've said you wanted this boat for charter. That being the case I'm pointing this out to you. If it's not marine plywood it won't hold up.
Last thing I see, and it maybe the camera, is the wood on the inside appears to have black mold growing on it. If you go further with glass on this wood you should consider killing that off before you put epoxy and glass over it.
Understand in no way am I busting your chops, I'm just looking out for you.
Re: XF 20 Build
it's marine plywood I know that for sure. as for the boat I hit the entire inside with 60 grit sand paper to knock of the dirt and grime, blew it out, and wiped everything with acetone. primed all joints with epoxy then used west systems 405 fillet filler mixed with epoxy to fillet everything in. Next to tab everything in with the biaxle tape. The working time on this slow cure epoxy is amazing compared to poly...
Re: XF 20 Build
a picture of the finished fillet, ready for tape... I cant get the pictures to upload in order.
- peter-curacao
Re: XF 20 Build
As I understood it's the type of lamination glue that makes ply marine ply so I'm not sure how to detect that from pics, fillets and tape I would have done wet on wet but that's me.
Users browsing this forum: Google [Bot] and 5 guests
