FS17 build, Take 2, lol. As some of you guys know I ran into some trouble building my last strong back and frames. I had something off to where I couldn't line up the stringers correctly. This could be because I tried to modify the stringer height, or transom thickness. Either way it bothered me enough to where I just wanted to start over. I'm going to build the shell to plans then make some modifications after the hull is flipped over.
So the last strong back I tried using 2x4x8's as they were the best thing I could find. Even though I leveled and straightened them as best as I could I can't be sure the issue wasn't there. I'm not willing to try that again so I decided to build my own strong back runners.
I got a piece of Sanded ply. Cut it into 6" strips and laminated it together.
Even after all that I wasn't 100% happy, so I snapped a chalk line and cut them down to 5.5". This is as straight as I can possibly get it!
A couple of notes here. I was amazed how many screws I used building the previous strong back. If you think you have enough, double it.
Also I went to go buy one of those big nice drywall squares to cut my new frames with. Well they are pinned together parts to make the 90 degrees, which I don't like, I wanted a one piece tool. I decided to check them prior to buying, and by the time you are 48" out they were at least 3/16" off! I guess drywall doesn't need to be that accurate, but I'll stick to a t-square and ruler.
The Plytanic 2.0 - FS17 Build
Re: The Plytanic 2.0 - FS17 Build
Good move, now you will not have something bugging you in the back of your mind for the whole build. The base for your frames is like the foundation of your house, if it ain't right nothing is right.
Like all things dry wall squares depend on the pride of the manufacturer. My builder would never allow 3/8" difference over 4' nor would I. There are squares out there that are dead on but you pay for them. When I was laying out my C17 which I never finished I double checked it for square and it was right on, but it cost me $$.
All edges on drywall are covered. And mud covers just able every possible error. So yeah... no need for square.
I was hoping to get a lot done today, but the kids are off of school. I did manage to get the strong back finished.
It is square to withing 1/16", and level across 6 fields length wise and 4 across the beam. I don't think I can get it any closer.
Good work silentneko!!! Jeff
Online
There’s a trick for right angles on this website. Use a full sheet of ply. Line it up and slide it across the other sheet.
I was trying to do something similar ealier, but I'm out of room. My garage inventory has grown over the years, tools, rolling tool chest, standing saw, work bench..... I under estimated the amount of room the FS17 needed to be built. Not a big deal, I can make it work, but I'm suckling in my gut to get around some places, lol.
You can also use trigonometry as a "square".
A 3"x4"x5" triangle is a right triangle.
Any multiple of this holds true, 6x8x10, 9x12x15, 12x16x20.
I did that to double check my last frames. Mostly I'm using a large framing square (big metal triangle) and a thick ruler, which work out very accurate. I saw a drywall T recommend on one of the old tutorials here so figured I'd try.
Users browsing this forum: OneWayTraffic, Yandex [Bot] and 9 guests
