Hi there,
Wondering if anyone has built one of these to suit a tiller outboard, and what modifications to the standard design are required to create a suitable and comfortable driving seating position in the stern?
Also curious as to whether anyone knows whether someone in New Zealand has built one?
Cheers
Mark
PG20 and PG22 for tiller outboard
Re: PG20 and PG22 for tiller outboard
Welcome Mate, I’m sure someone will answer or have an opinion
Happy New Year
Happy New Year
Building " Shallow Mine "
http://xf20shallowmine.blogspot.com/201 ... -mine.html
Welcome yes you can do a tiller version of either of these. You will want to use an extension for the tiller and move some of the weight forward. I do not know of any one in NZ that has built a Panga but that doesn't mean one hasn't been built, not all builders post there builds.
Hi,
Any objections to rearranging the interior of the stern to something like in this image?
https://i.ytimg.com/vi/v1CAx0HVxMU/maxresdefault.jpg
Cheers
Cheers
Can we have a better picture of what you have in mind?
There is no problem with a tiller version as long as the HP is reasonable or then, use of those hydraulically assisted tiller systems.
Hi there,
Thanks for reply, here are a couple of sketches attached which are more along the lines of how I've typically seen tiller boats set up. E.g. fibreglass pangas for example.
It looks to me that I'd have to deviate from the bateau design to run a tiller motor. It looks too awkward, the operator body position is forced too far forward in the design, all that structure is in the way, operator needs to be sitting 'with' the motor, not reaching back for it.
Does that make any sense?
Has anyone built a tiller one before?
Regards,
Regards,
Fellow kiwi here, where in NZ are you based?
I’d keep the same basic setup at the rear myself and build a bench in front of the motor well. I would not worry about trim, build a ballast/livewell forward and fill it when solo.
The tiller arm for most 60hp outboards puts you about 2-3 feet in front of the transom.
Edit: I don’t have panga plans but in the fs17 plans the motorwell frame is about 60cm forward. You can add more to make a seat if you wish. The motorwell cutout could also be smaller if it’s a tiller. In that boat at least there is lots of room to use a Tiller as long as you plan for a good trim.
This is your Boat. If you respect the scantlings, and build everything under the sole as to plans then you have enormous freedom in arranging the other stuff.
I like a long extended tiller but with a big engine, you need a strong, stiff extension. If you are alone in the boat, you must pay attention to the trim. That can be done as others have said by moving weights forward or with the extended tiller.
Move the seats and frames to your preference as long as you keep a rear bulkhead and keep part of the frames under the sole and under the gunwale.
Ok thanks for reply.
Planning for 50hp, no tiller extension, will manage trim with distribution of weight.
Comments on frames under sole and meeting gunwale to stiffen the latter are understood, but can you please clarify the purpose of the bulkhead, to help me solve:
- Could bulkhead be replaced with a frame, provided transom still had forward/aft bracing?
- Or alternatively, could bulkhead be reduced to form a seat as shown in the following sketch? (minimum transom-bulkhead distance?)
The first 30 seconds of this show the driving position I'm aiming for. https://www.youtube.com/watch?v=k490an6gdA4
Hi, did that make any sense, any feedback on this?
Is there some other way to contact this company?
Users browsing this forum: Bing [Bot], Google [Bot] and 11 guests
