Imgur Album
I screwed the sheer panels on, attempting gain 6" at the stern to 9" at the bow. We just couldn't get the shape to work, the panels wanted to tilt out too much. Ended up adding 6" bow to stern as designed. It looks ok, but not what I wanted. The front half foot falls off noticeably, from the shape of the panel, but I can hide that with the rub rail.
Imgur Album
Next day my friend who is rebuilding his boat came over to cut up a piece of mahogany on the new table saw, to make strips he will laminate his rub rail from. Saw cut it beautifully, really happy with it. We also too another stab at installing the sheer panels. My friend is a big strong guy, and with him pulling up and forward, and with me angling the screws to pull the panel forward, we were able to get the panels screwed on exactly how I had wanted, 3" higher at the bow. Anchored the stern then just worked towards the bow forcing it a little bit with each screw. I'm much happier with how the boat looks now. There is a little hump in the panel, so I'll re trim it based on the rub rail once that is installed to get the final shape, which might look even a tiny bit more bow up.
Imgur Album
I protected the rest of the primed surface with carpet film and painters tape, sanded the primer where the panels attach, the glued them on with gel magic. The fact that the front of the panels now extend 9" with only 3" of over lap would be concerning, except that I will be bringing the interior biax all the way to the top of the sheer, which I suspect will be plenty to hold the panels securely.
Imgur Album
I also used the table saw to cut strips of 3/8 plywood and remove half the thickness of the stringers from the top inch with a dado set. This is all to add 2-3/8 inches in height to the stringers with offset strips. 2" because that's how much I'm raising the sole, and 3/8 because they were that undersized. Don't know why or how but when I looked at them I had sharpied on "3/8 undersize" and sure enough hey were. Ahh well, the sole is the on other thing I cut before deciding to raise the sheer, that will have to be tweaked. I'll glue those stringers up and start glassing the inside next weekend.
