Just started on an XF20. Got the stringers, sides, front and rear transom, and part to the tunnel cut out. Will keep ya posted on progress.
Checking in on transom thread from Boo. I cut the transom 4" higher than the plans show just in case. It's easier to trim it down than to add more wood. May not know the correct measurement until the jackplate and engine are trial fitted and holes marked for drilling.
More later.
Building an XF20
- dwhiteboy_672002
XF20
Hey gpratt, how's it going? I've just ordered my plans for the XF20 and soon my journey towards this project will be on its way. May I ask if you might give a few pointers as you go along to help others and myself in what not to do,. Like the tunnel,. Don't know yet whats up there but a little info would be great for when I start,. Thanks and hope you have a blast building this boat,. Hope I do as well.. /
whiteboy
Is this your first boat? If yes you picked a good one to get the hang of it. Anytime you have doubts post your concerns here and you'll get help.
Layed out the bottom panels tonight and will cut them plus some other parts out Sat. Then decide how to hold this thing off the ground to put it together. Most likely use horses till the first roll then rig something up on wheels to do the glass sanding outside. I didn't sand out side on my OD16 and my I paid the price later. Everything was covered in glass dust. Half the stuff in the garage still is!
Let's do it!
Let's do it!
- dwhiteboy_672002
white boy
I worked on the boat a good bit this weekend. I have all the parts cut out except the casting platform. It can't get done until the hull is completed since its getting moved up to the sheer line.
Started glueing up the parts today. I'm using the Silver Tip with slow hardner. I've used S3 with medium and liked it. Jury is still out on the slow. I'll know more in the morning. It's been several hours and it's still wet to the touch. When using medium I could wait a couple of hours and it would be starting to setup. That's when I'd add the glass over fillets. This slow may add to my building time. If it does I won't be using it again.
I have pictures to post just haven't done it yet.
Stay tuned!!
Stay tuned!!
I apologize for picking nits, but there have been very few flames on this board in the last two years. For the record, writing "I think that's a bad idea" is not a flame. A flame is a personal attack. Saying "Here's why I think your idea is wrong" is just an opinion on a technical subject.LIVEWIRE wrote:if you had asked that 6 or 8 months ago like i did you would have been flamed for sure, but it seems the flamers have changed their tune a little since one has been built .
- dwhiteboy_672002
gpratt
Sounds like your coming along great on the boat,. What type of climate have you had there in the last few days? I worked on a few boats here during the summer time and man what a time I had, So I'm thinking of what type or hardener to use myself,. Hope things go smother for you here on out,. Would be great to see the pic's when you post them,.
Users browsing this forum: Bing [Bot] and 13 guests
