FS14 Build - Pics, etc.
OrangeQuest
Re: FS14 Build - Pics, etc.
Post by OrangeQuest »
It looks good! Just hope you have enough clamps!
Bogieman
Post by Bogieman »
OrangeQuest wrote: Sat Jul 14, 2018 2:29 pm It looks good! Just hope you have enough clamps!
I'm guessing he does, OQ! Makes things a whole lot easier when you have that many.
Looking good.
finalfront
Post by finalfront »
Clamps are like cow bell, never enough...
finalfront
Rubrail sanded & coated with resin.
Skeg with one layer FG.. Hmmm. More, less?
finalfront
So, I struggled with laying 6 Oz FG tape over skeg. Even though I rounded edges & did use some fillet on bottom joint, it did not stay put & created bubbles all along corners. Apparently not rounded enough at corners, & I had to sand it off. I'm thinking if skipping FG over skeg. Can't see where it's part of plan anyhow, but I did want tough skeg for rough shore. Any thoughts on what I should do? Or just leave it as sacrificial & call it a day with a couple coats of epoxy resin & bottom paint.
OrangeQuest
Mix graphite in with your epoxy and do to the shear line.
One thing I did to help my tape form around the 90 degree angles was fold it and put weight on it for a few days. After wetting the area I am putting it I lay the tape against the corner and stick one side, unfold and stick the other. The crease of the fold in the corner.
finalfront
I'm thinking graphite mix may be good & tough enough for skeg & good bottom cover too. However, I have silvertip epoxy bottom primer & Trinidad bottom paint already. These two seem pretty tough. Should I consider epoxy graphite mix as add'l pre-coat. Or stick with what I have?
OrangeQuest
I said shear but the chine.
Isn't the Trinidad paint for a boat that will stay in the water for long periods at a time? I think what most builders do is just use the graphite mix for their bottom layer.
Capt UB
Post by Capt UB »
finalfront wrote: Sun Jul 15, 2018 9:42 pm I'm thinking graphite mix may be good & tough enough for skeg & good bottom cover too. However, I have silvertip epoxy bottom primer & Trinidad bottom paint already. These two seem pretty tough. Should I consider epoxy graphite mix as add'l pre-coat. Or stick with what I have?
The epoxy/graphite is for protection from sand/oyster bars, hitting things. Trinidad is for antifouling of marine growth. The two are not the same.
finalfront
True. Boat will be in water for 3 to 4 months.. Maybe go with primer & then epoxy graphite mix (then Trinidad as last coat or just epoxy graphite mix as last coat)?
Users browsing this forum: Google [Bot] and 10 guests
