Beautiful boat What power is on it and how does it run?
The waterline shows it to be pretty tail heavy. I am sure moving some weight forward is going to help things a bunch.
Mark's PH18 in Toronto
- BarraMan
Re: Mark's PH18 in Toronto
Wow, great looking boat! However, it is clearly very tail heavy.
I think its a no brainer - move your trolling motor batteries to the front, then see how it sits.
I can't do the maths, but ideally the trolling motor batteries should be close to the motor anyway.
You could always just move the batteries to see how much it improves the trim. If it is enough then do the rewire.
Thanks everyone. I was wondering if anyone may have a calculation, but yes I can just do it. To move anything back is going to be a PITA due to all teh wiring that I have to re-do.... I plan on moving 3 - 2 for 24V TM and the one for 12V accessories (dedicated starting battery is #4)
Perhaps what I will do is move two, then the third if need be.
Power is a 2004 Evinrude 115 Ficht, purchased new (on my previous boat) 344 hours to date, runs like a top no issues ever, sips gas (except on tournament day when it seems to have only one throttle setting LOL)
If Jacques can tell you where the design center of gravity is you can then figure out where your actual cg is then move things around. To figure out where it is you could weigh the boat and trailer. Then weigh the tough weight. With that you can figure out the actual cg then with that how much you have to move. My guess is the cg should be 1/3 the length forward of the transom?
All that said Jacques is the expert and designer. You don’t want to move forward of the design cg as bow steer might become an issue? Boat looks great ! Nice work. Envy you boating in that area.
Could you just put the boat in some water, disconnect the trolling bats, move them forward a bit, then see how she sits? Might be easier than the math.
- BarraMan
Yup! You don't have to be Einstein to see that that boat is seriously tail heavy. The trolling motor batteries (2 x ) are a no-brainer relatively easy move for starters.
Mark you can do the calculations on how much you need to move forward. Assume the COG is 42% from the transom at the water line. Then say a battery weighs 60 lbs and distance from where the battery is no is 10' so you move it to the COG that is 600 lbs then you move it another 4' forward and that is another 240lbs. So by moving that one battery you have changed the weight of the effective COG by 840lbs. What you can do is take one of your batteries and move it forward and see how much a difference it makes, before you do any permanent changes. This will give you an idea of how many you might actually have to move. You may only need to move your trolling battery and house battery forward.
- BarraMan
All true Tom but ..........
24V trolling motor therefore 2 x 12V batteries to run it. These are the easiest batteries to move cause it would only involve rerouting and shortening the cables. I cant imagine moving only one. Ideally they should be close to the TM anyway. Moving the house battery would involve more rewiring. I suggest you just move the TM batteries to a forward position only (without touching the cabling) first to see how the boat sits. Then if it looks OK remount and rewire them. Looking at how that boat is sitting now I’m gonna be surprised if that moves the C of G too far forward.
Just saying!
Just saying!
