Teardrop trailer - first images
Evan_Gatehouse
Post by Evan_Gatehouse »
Hey,
Got inspired the other night and pushed the design forward. The issue I have with most teardrop trailers is that no standing headroom. And an outside kitchen; which isn't as much fun in the rain.
This design is clever. The upper portion is like a shoebox lid with tall sides. When lowered, it is behind the slipstream of a small car. It has a queen size bed, with storage under the bed big enough for several typical Rubbermaid 25 gallon totes. Keep your clothes, food, and camp chairs under the bed. When raised you can stand in the back part of the trailer in the small kitchen area. You can sit on the bed and cook if it's raining. If it is nice outside find a site with a picnic table and use that.
To lift the upper portion you can get 2 strong people and just lift and pin it in place - but at about 160 lbs there will be an option to fit a simple central lifting jack mechanism. It uses an acme (square thread) screw, a cordless drill and will do the job with a lot less effort. I'm sure 90% of people will choose this option.
The car pictured is a Mazda 3 hatchback; a pretty small car - but you can see how the lowered trailer is tucked well behind the car.
Raised. That's a 6' person. Who is green, like most of us.
3D view - see how the top part of the trailer slopes inward and the front slopes back? All in the name of good aero.
Trailer lowered for trailering. Very slippery shape
SK17,MM21/MT24
jacquesmm
Re: Teardrop trailer - first images
Post by jacquesmm »
Looks good.
Southern Gent
Post by Southern Gent »
Evan, nice design, consider using gas charged lifts to overcome the roof weight factor. Best wishes
Grit19
Post by Grit19 »
That does look good. Very creative. Will this be a stitch and glue construction too :lol:
There ain’t no ride like this in Disneyland!
gonandkarl
Post by gonandkarl »
Hi,
I like this design and when living in South Africa I always wanted to have such a caravan. You could buy them from a trailer shop which made them fold away as they called them. This might be an idea for your design to make the 4 walls that lift up out of canvas and have just 4 corner struts which hold the roof up.
Something like this :
But please carry on with designing it with lots of pictures it interests me as much as all the boat building pictures.
Greetings from Karl
All pictures of Micro Petrel AD14 and FS13 :
http://gallery.bateau2.com/index.php?cat=87433
Post by Jeff »
Evan, I very much like the design!!! Much more useable than the teardrop, especially for us bigger guys!! Jeff
Eric1
Post by Eric1 »
Very nice Evan!
Evan_Gatehouse
Thanks for the idea for gas struts. I'll consider it.
I wanted to avoid canvas sides like a pop up tent trailer - because not everybody who can sew.
Yes, it will be stitch and glue style construction.
SK17,MM21/MT24
Evan_Gatehouse
Now if anybody can point me to a supplier of gas springs with the following specifications:
- 24" stroke (this seems to be the hardest thing to find)
- lift force about 100 lbs
- off the shelf - not a custom gas spring. I want one that anybody can easily order
- reasonable price, say $25 - 50 each.
(I also looked into linear actuators but they are about $150 each and you need 1 on each side)
SK17,MM21/MT24
OrangeQuest
Post by OrangeQuest »
Garage extension springs will cost around $20.00 for a spring that can lift 150 pounds 7 feet. If you need to only lift a few feet then the correct pulley system could lift 300 pounds with one spring. Then if you have the weight that needs to be lifted counter balanced you can use a window motor to lift and lower by switch.
https://www.bing.com/images/search?view ... ajaxhist=0
