My cx 25
dalnilo
Re: My cx 25
Post by dalnilo »
Fuzz wrote: Fri Sep 14, 2018 2:28 pm I think the rubber strips are something needed for aluminium tanks. I do not think they are needed for plastic tanks. But as advised check with the manufacturer and do as they say.
I will probably use a similar product
Extruded physical cross-linked extruded polyethylene Density: 30/33 Kg / mc Color: anthracite gray Thicknesses available: from 2 to 12 mm Material description: Closed cell polyethylene foam. Extruded lattice. Excellent physical properties in the static and dynamic field, elasticity, thermal deformability, shock absorption. Thermal insulation, minimum water absorption, low water vapor permeability, resistance to water atmospheric agents, non-polluting, behavior inert chemical. Applications: boating, sporting goods, packaging, camping, construction industry, automotive, healthcare, lighting.
danieloldhouse
Re: My cx 25
Post by danieloldhouse »
dalnilo wrote: Sat Sep 15, 2018 2:55 am
danieloldhouse wrote: Fri Sep 14, 2018 6:01 pm Are those tanks HT-Tanks from Nautica FAM?
Ciao
Sono osculati
Thanks, how much have you paid for them?
Grazie, quanto hai speso?
dalnilo
Re: My cx 25
Post by dalnilo »
danieloldhouse wrote: Sat Sep 15, 2018 4:11 am
Ciao
Sono osculati
600 € for the couple
danieloldhouse
Re: My cx 25
Ohh, I believe it's a very good price
dalnilo
Re: My cx 25
Post by dalnilo »
danieloldhouse wrote: Sat Sep 15, 2018 6:49 am Ohh, I believe it's a very good price
I bought them both because they do not corrode and because of the good cost on the other hand, you only need to raise the floor by 3cm
danieloldhouse
Re: My cx 25
dalnilo wrote: Sat Sep 15, 2018 6:59 am
It really seems they were built for your boat, what's the capacity of each one?
Raising the floor of 3cm is very easy, just add a wood strip on the top of the stringers and you're ok, in a big boat like that 3cm is nothing :wink:
cape man
Re: My cx 25
Post by cape man »
A vented tank is required to eliminate thermal expansion. All the expansion on a poly tank is chemical if vented. The liquid fuel doesn't shrink or expand with temp change, it's the gas vapor above.
dalnilo
Re: My cx 25
Post by dalnilo »
in your opinion what is the right fitting for the assembly? the drawings say about 20cm on the side but do not say height
dalnilo
Re: My cx 25
Post by dalnilo »
thb
Re: My cx 25
Post by thb »
Dainilo,
Those are very nice looking eyes. I think placement of the stern eyes depends on what they will be used for. Is this boat going to be trailered? If so, I would place them about where you are holding them. What else would they be used for? If for towing someone, I would place them higher. I am not sure about using them to lift the vessel, but if that is the purpose of having them, then place them higher as well.
I placed mine on the FS17 about 2 inches down from the top of the transom and about 3 inches in from the sides.
Your work is looking great. What a huge boat.
P/S I lived in Naples as a boy for 2 years while my dad was stationed there.
Regards
Tom in Steinhatchee
