If I did it that way there would only be 3 days in the year I could lay epoxyOrangeQuest wrote: ↑Thu Jan 10, 2019 8:13 am Not only dropping temps but in high humidity the moisture will want to stick to everything. Increases risk of epoxy wanting to blush. I avoid epoxy work if temps will be in the low 60s in a 24 hour forecast.
Panga 20 Build
Re: Panga 20 Build
Re: Panga 20 Build
you barely have 3 days a year where your tongue won't stick to a metal pole!Fuzz wrote: ↑Thu Jan 10, 2019 3:27 pmIf I did it that way there would only be 3 days in the year I could lay epoxyOrangeQuest wrote: ↑Thu Jan 10, 2019 8:13 am Not only dropping temps but in high humidity the moisture will want to stick to everything. Increases risk of epoxy wanting to blush. I avoid epoxy work if temps will be in the low 60s in a 24 hour forecast.
- BB Sig
Re: Panga 20 Build
I wish we could "like" posts!Jaysen wrote: ↑Thu Jan 10, 2019 3:44 pmyou barely have 3 days a year where your tongue won't stick to a metal pole!Fuzz wrote: ↑Thu Jan 10, 2019 3:27 pmIf I did it that way there would only be 3 days in the year I could lay epoxyOrangeQuest wrote: ↑Thu Jan 10, 2019 8:13 am Not only dropping temps but in high humidity the moisture will want to stick to everything. Increases risk of epoxy wanting to blush. I avoid epoxy work if temps will be in the low 60s in a 24 hour forecast.
- OrangeQuest
Re: Panga 20 Build
The months March, April, May, October and November have a nice average temperature.
Hot season / summer is in May, June, July, August, September and October.
On average, the warmest month is August.
On average, the coolest month is January.
The average annual maximum temperature is: 80.6° Fahrenheit (27.0° Celsius)
The average annual minimum temperature is: 60.8° Fahrenheit (16.0° Celsius)
The monthly mean minimum and maximum temperatures over the year in Houston, United States of America.
Average min and max temperatures in Houston, United States of America Copyright © 2019 www.weather-and-climate.com
Notice they only list a hot season (6 months), no cold season or cool even. But we do have 5 months that are considered "nice" season.
I can afford to be picky on when I sling epoxy or paint!
Re: Panga 20 Build
Been ranging between 22 and 41 here. Not that conductive to epoxy....OrangeQuest wrote: ↑Thu Jan 10, 2019 7:27 pm The months March, April, May, October and November have a nice average temperature.
Eric (aka, piperdown)
Re: Panga 20 Build
I cut all the stringers this evening. I'll epoxy and tape the seams tomorrow night. I should be able to keep my garage warm enough for the epoxy to cure. If I'm going to notch my stringers and frames, should I splice the stringers on one side and then splice the other two stringers on the other side, then epoxy glue the two long stringers together?
Re: Panga 20 Build
What is the transom angle at the DWL? It looks totally square to me. What am i missing?FluidDynamic wrote: ↑Wed Jan 09, 2019 9:41 pm The epoxy cured. No problem.
I placed the transom a little earlier. I ran out of 2x4's so I had to temporarily brace the transom. I'll build something more substantial tomorrow. On my plywood cuts, does it matter if it's off a little. The transoms edges overlapped each other a little. I'm assuming this will be taken care of with either sanding or epoxy putty? I guess the stringers are next. I've been checking the cross dimensions and the dimensions between each frame. Everything is lining up. The stringers should go in no problem. The stringers will be cut with notches. I'll have to cut notches in the frames.
Re: Panga 20 Build
Sometimes the pictures are deceptive. I also built my transom at 14 degrees to dwl, so that mght impact my perception.
Re: Panga 20 Build
Do you mean splice with fiberglass? The two pieces of plywood used to make the stringer should have their joints offset by a foot or more. Once the two are glued together it is like one solid piece of wood.FluidDynamic wrote: ↑Thu Jan 10, 2019 11:34 pm I cut all the stringers this evening. I'll epoxy and tape the seams tomorrow night. I should be able to keep my garage warm enough for the epoxy to cure. If I'm going to notch my stringers and frames, should I splice the stringers on one side and then splice the other two stringers on the other side, then epoxy glue the two long stringers together?
