fairing material question?
Bogieman
Post by Bogieman »
What do you guys recommend for a good general purpose fairing compound? I'm trying to avoid Quickfair because it'a too expensive.
Bogie
Dr. Pete
Re: fairing material question?
Post by Dr. Pete »
BBC has a mix that is micro ballons, silica? It’s easier to work than the wood flour. I got by without Quick Fair so far. Wood flour is the least expensive but is a harder material to sand etc after it is cured
terrulian
Post by terrulian »
Folks love Quick Fair and I did use some on my build but I've always just made my own from microballoons, and when called for, cabosil and/or milled glass.
Tony
jacquesmm
Post by jacquesmm »
Many builders do the rough fairing with a mix of resin, micro balloons and silica and finish with QuickFair.
Capt UB
Post by Capt UB »
jacquesmm wrote: Fri Mar 22, 2019 11:28 am Many builders do the rough fairing with a mix of resin, micro balloons and silica and finish with QuickFair.
That what I'm doing on the LM18. You get the weave filled in and a lot of the low spots, cheaply. QuickFair is what I use for finishing, then S3 Yacht Primer.
terrulian
Post by terrulian »
What Jacques and the Captain said.
Tony
Bogieman
Post by Bogieman »
Well that settles it. Thank you!
Capt UB
Post by Capt UB »
You may know this already...
sift micro balloons and silica and wood flour mix (mix A)
mix the resin/hardener (I use the slow hardener) (mix B)
mix the two well (mix A and B)
pour out on a cookie sheet (doesn't go off as quick)
There are other ways of doing this, but this does work
TomW1
Post by TomW1 »
Do not use wood flour in a fairing mix, it makes it hard to sand. You can buy a premixed fairing mix from here consisting of balloons and silica or mix your own of one part silica, one part balloons and one part epoxy. I think that is the right mix but check with Reid.
Capt UB
Post by Capt UB »
Bogieman wrote: Fri Mar 22, 2019 10:28 am What do you guys recommend for a good general purpose fairing compound? I'm trying to avoid Quickfair because it'a too expensive.
Bogie
https://forums.bateau2.com/viewtopic.php?f=4&t=63190
I did mix wood flour with the the fairing mix from BBC. Used a long straight edge to level the mix. A few hours later I used a long board with 40. It filled in the weave of the cloth. If I had waited a few days, It would have been hard as a rock. You don't leave clumps and runs, level them now, wipe the run off.
First time was bad! It's gets easy after that. The guys on this forum told me to add to the wood flour and not use wood flour by it's self.
