DE 24ish
Re: DE 24ish
Homemade microlams and all the parts either came down the stairs or out the window
Re: DE 24ish
Started assembly March
Re: DE 24ish
The last sections of the bottom and sides needed to be glued up down stairs
Re: DE 24ish
That brings us up to today, glued up the final pieces on the side panels should start to stitch thinks together this weekend.
Bought gel majic for the transom and the hull seams. Also got empty caulking tubes. Stringers were bonded with epoxy and wood flour.
Re: DE 24ish
Lookin great!
Question, did you make a template for the puzzle joints or route them freehand?
Eric (aka, piperdown)
- remedy32
Re: DE 24ish
Like it. Keep on posting. I'll ask the same question.....
CT USA
BillQuestion, did you make a template for the puzzle joints or route them freehand?
CT USA
Re: DE 24ish
I made a template
Start with a hole saw and jig saw make some lines sand it until your happy with the fit.
All you need to do is make one and then duplicate it using a ball bearing router bit.
* Make sure to mark centerlines on your templates. Watch the orientation of your pieces as you go.
When routing actual pieces I will remove most of the material with a jig saw first to within about an 1/8 “ then clean up with the router.
Re: DE 24ish
Nice work!!! Jeff
Re: DE 24ish
Very nice work and thanks for the explanation on the jig!
