redfishla wrote:The next boat is to be started in the spring of 2005. My wife's buying me a set of plans for x-mas. Could someone "in the know" such as Jacques
answer a few questions comparing the Panga 22 and PH22?
Fools rush in on Sundays when Jacques is taking the day off. So here goes...
redfishla wrote:1) Which boat would be more stable in a marsh setting?
The PH22.
redfishla wrote:2) I like the PH22 because I could do some light offshore fishing. How does the PH22 compare to the panga in that area?
The panga will safely handle higher waves. Flats boats prefer flat water.
redfishla wrote:3) I worry about the high bow of the panga. Is visibility hindered at all?
The PH22 will definitely have much better forward visibility. That high bow is one of the things that makes the panga a more seaworthy boat.
redfishla wrote:4) As an "all around" boat, which one is the least one-dimensional (basically, which is most versatile)?
If you are in water deep enough to float it, the panga is more versatile.
redfishla wrote:5) Lastly, which one is the least complex to build?
The panga looks easier to me, and requires less materials, too.
Now, as usual, we can sit back and wait for Jacques to give the real answer.
